How to install opensuse on Pinebook pro
I am trying to install opensuse on my pinebook pro and feel stupid for asking this ... but how ?
I downloaded the iso from https://github.com/smithmcgriff/openSUSE-on-pinebookpro
and then I put it on an sd card.
My pbp boots from it but all I get is a terminal. I think it just boots from the sd card but how do I get the image to install on the internal drive in the pinebook pro?
Also a small side question:
How bad of an idea is it to simply get the aarch64  image from opensuse (https://software.opensuse.org/distributions/tumbleweed) and install that on the pbp?
(05-16-2020, 02:06 PM)oldmansaur Wrote: Hi,
There are some tips in this thread:
https://forum.pine64.org/showthread.php?tid=9047
You can just write the original opensuse version to a sd card and try if it works. You won’t damage anything that way. I guess you still need to do some configuration though. Also it depends which kernel opensuse is using, currently development in the Pinebook Pro area is very vibrant, so every new kernel offers a bjt more out of the box.
  Boot Order in Pinebook Pro food 12 18,693 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,353 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,139 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,720 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,350 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 7,040 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,879 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,506 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,687 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,373 03-31-2024, 10:11 AM
Last Post: u974615
