(03-16-2020, 02:41 PM)dhosh Wrote: 5.6.0-0.4-MANJARO-ARM
LibreOffice:
Version: 6.4.1.2
Build ID: 6.4.1-3
CPU threads: 6; OS: Linux 5.6; UI render: default; VCL: kf5;
Locale: en-US (en_US.utf8); UI-Language: en-US
Calc: threaded
When working with documents in Writer, I get random pastes of what appears to be in my clipboard.  I likely pasted the text once, but it shows up in multiple random locations in the document.  I can go through and clean them up (delete them), and I swear they pop up elsewhere!  I can go to Manjaro's clipboard and clear it, and they still seem to creep in.
I have found a similar post regarding LibreOffice, and they pointed to hardware, or OS issues.
Anyone else see these issues?  I have not noticed this happening in any other application, but then again, I don't write a lot of text in any other application.
I will try to replicate this situation and then report back.
Manjaro ARM Team.
I've cloned my live SD card (on which I'd installed Manjaro) to the eMMC using dd. It worked like a charm at first try, but digging deeper, I've realized this was a risky move, that I should have used cat or something else. So please, don't do what I did, unless you want to.
Creating is Everything
Away
oh... that is what the emmc installer is for...
your sdcard clone is probably broken, you just aren't yet aware.
(03-23-2020, 07:29 PM)8jef Wrote: I've cloned my live SD card (on which I'd installed Manjaro) to the eMMC using dd. It worked like a charm at first try, but digging deeper, I've realized this was a risky move, that I should have used cat or something else. So please, don't do what I did, unless you want to.
Pretty sure dd is the way to go, this is how I copied Manjaro from the SD card to eMMC, too and it is working.
There are a number of directories that should NOT be copied,
they are empty until booted,,, dev, sys, proc, run
The directory should exist, empty
dd copies it and contents, and then it is not empty
rsync is the way, specific directories (all but above)
I should be more clear, I copied the disk device directly, not a mounted system. Computer was booted off an SD card, the Manjaro that was working for me was in an SD card reader in the USB slot, then I copied it from the USB to the eMMC with dd and it works.
How frequently should my install be getting updates?  I've been using the updater through KDE discover and haven't had any for a while now.
(04-13-2020, 09:56 PM)inspiredrat Wrote: How frequently should my install be getting updates?  I've been using the updater through KDE discover and haven't had any for a while now.
You may need to switch to the new mirror list: https://forum.manjaro.org/t/another-mirr...red/132302
I just followed the instructions on the thread and now my Pinebook Pro will not boot.  It seemed as if the updates ran correctly from the terminal.  When I tried to reboot the only thing I get is a red light.  Can you please let me know what next steps might be in troubleshooting?
Ah sounds like this issue: https://forum.manjaro.org/t/arm-stable-u...s/133266/2
  Boot Order in Pinebook Pro food 12 13,649 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,524 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,933 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,265 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,832 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,520 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,792 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 108,372 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,787 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,363 03-31-2024, 10:11 AM
Last Post: u974615
