Manjaro 20.04 released
>/dev/mmsbl1 ,, I hope this is a typo
You can't mount whole card, only partitions,,,, /dev/mmcblk1p1
There is a systemd service (don't know name), or try startx or init 5
I just did a google search for "manjaro pacman history" and got "cat /var/log/pacman.log" So, if you ca get to a root console you might be able to find out what you removed. You can then try to reinstall with "pacman -Si <package>". I am a debian/ubuntu user, (but have also found that Manjaro seems to be the best distro on the PBPro) so check the commands I mention by looking at the man pages for pacman first.
If you can flash a SD card, on another computer, try the 20.04 SD card version of Manjaro. If it boots, you can use it to help.
(04-06-2020, 04:48 PM)mainer Wrote: I just did a google search for "manjaro pacman history" and got "cat /var/log/pacman.log" So, if you ca get to a root console you might be able to find out what you removed. You can then try to reinstall with "pacman -Si <package>". I am a debian/ubuntu user, (but have also found that Manjaro seems to be the best distro on the PBPro) so check the commands I mention by looking at the man pages for pacman first.
Thank you. I flashed the installer image to a different SD card and I was able to re-install Manjaro. Not sure what the problem was, maybe an issue with the card I used initially.
(04-06-2020, 04:14 PM)wdt Wrote: >/dev/mmsbl1 ,, I hope this is a typo
Sorry, this was a typo I meant the partition not the device...
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,700 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,416 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,515 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,210 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,745 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,083 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,420 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,651 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,554 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,447 11-14-2023, 10:57 AM
Last Post: trifleneurotic
