emmc image will not flash
if I load (on OSX, with Balena Etcher or Pine64 Installer) Manjaro-ARM-xfce-pbpro-20.02-emmc-installer-20.02.img.xz to my SDcard and boot my PBP, i will see the Manjaro logo plus spinning circles for ever ( 2 hours then stopped ). Images like Manjaro-ARM-xfce-pbpro-20.02.1.img.xz however will boot ok but I don't know how to flash that on the emmc.
What am I missing in the process of flashing to emmc?
There are 3 options maybe more hopefully someone with more experience can chime in. The first one I haven't tried. Because you downloaded the emmc one and it's now booting from sdcard I think when you first power up after the first 10 seconds of black screen you press ESC and it should start the installer.
Option 2 is to get a usb emmc adapter and flash to emmc using Etcher.
Option 3 is after you booted Manjaro from sdcard download the image again and dd it to your emmc, once completed power down then remove sdcard and power back up. In this thread look at post#7 and replace the debian image with your Manjaro image in the wording of the code.
https://forum.pine64.org/showthread.php?tid=8229
Hope this helps.
There's a known bug in the Majaro image.
It remains stuck on the logo, a simple press on escape should make you see the menu.
too slow Big Grin
'simple press on escape' helped. Now, if oly I knew if to point at mmcblk2 or mmcblk2boot0 or mmcblk2boot1 (or mmcblk1 which is the SD card?
selected mmcblk2 and it works very well, Thanks to all!
(03-25-2020, 03:32 AM)FeMike Wrote: There are 3 options maybe more hopefully someone with more experience can chime in. The first one I haven't tried. Because you downloaded the emmc one and it's now booting from sdcard I think when you first power up after the first 10 seconds of black screen you press ESC and it should start the installer.
Hope this helps.
Thank you option 2 worked for me
Hope this helps.
Which adapter did you use? I only ask as I have lost the one I purchased from pine store.
Hope this helps.
I got mine from here but I believe the pine store is cheaper. I saw a thread somewhere here where there is a list of other sources for the adapter.
https://www.joom.com/en/products/1514200...3155020101
Hope this helps.
Thank you, I'll try finding the thread. I don't know how long it would take pine to ship another one.
Isn't it easier to work with a micro SD? It also saves you from opening the PBP.
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 2,791 01-03-2026, 07:09 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,242 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,543 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,663 10-23-2025, 09:38 AM
Last Post: jceaser
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 105,324 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 6,604 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 5,471 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 4,207 02-21-2023, 02:31 PM
Last Post: Idaho
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,759 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 12,454 02-06-2023, 09:11 AM
