Manjaro w/ Panfrost Drivers vs stock Debian Video Performance
see post 4 above
(03-20-2020, 03:45 PM)decisivedove Wrote: Setting the environment variable breaks the game. The graphics don't render. I am running Manjaro with Panfrost drivers.
Yes, you are right. I tried it out, and it seems GLES3 support in panfrost isn't quite there yet. The same is true for firefox with the webrender backend, it shows only some corrupted triangles.
this isn't true at all and i've posted the workarounds already.
https://www.gamingonlinux.com/articles/o...port.16094
They might have added OpenGL ES 3.0 support on Panfrost.
is there a reason you are ignoring the answers to your questions?
(03-24-2020, 11:22 PM)xmixahlx Wrote: is there a reason you are ignoring the answers to your questions?
In your first post, you mentioned that using gles3 it could support graphics quality 2. You also mentioned that you were getting 60 fps in testing. Your answer seemed to imply that you got the game working in gles3.
Maxjrh suggested setting the environment variable PAN_MESA_DEBUG=gles3. I tried that and replied to him that it was not working. You then told me to look at post 4 above. And when he replied, you claimed that you had already posted a workaround. What workaround were you talking about? I could not find the workaround. After researching a little more, I figured out that we had to disable Advanced Pipeline for STK to work in  gles 3. In the link I posted, it mentions to use the non-deferred renderer.
You kept redirecting me to post #4 where I could not find any workaround. I know you were only trying to help. I should have more responsive and tried to get it clarified.
I am sorry that you felt ignored.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,044 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 17,358 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,500 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,549 02-19-2025, 12:49 PM
Last Post: zkajdan
  Inexpected reboot during watching youtube video regivanx 1 3,187 10-19-2024, 06:02 AM
  Official Debian support moonwalkers 64 115,222 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  (xorg) Video driver? falken 2 4,318 07-03-2024, 12:01 PM
Last Post: falken
  Debian on Pinebook Pro u974615 7 11,502 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 3,823 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 3,865 03-01-2024, 06:46 PM
Last Post: Puckla
