Manjaro XFCE: video outputs (Multi-monitor)
Question
Connected USB type C to DP device: it works in mirror mode.
Manjaro XFCE only displays one video output: "default"
$ xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
  1920x1080      0.00*
GUI settings ($ xfce4-display-settings -m): only one monitor ("default")
How to configure two separate monitors?
P.S. Default Debian: no problems (eDP-1 and DP-1 video outputs).
(03-22-2020, 11:37 AM)EreTIk Wrote: Connected USB type C to DP device: it works in mirror mode.
$ xrandr -q
  1920x1080      0.00*
that came up a few times on manjaro arm forums
the suggestion was swap drivers :
sudo pacman -S mesa-git
sudo pacman -R xf86-video-fbturbo # or xf86-video-fbturbo-git
then reboot
it worked for me Shy
Thank you very much
But without xf86-video-fbturbo-git, the rendering speed in xfreerdp is very low
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,406 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,017 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,109 02-19-2025, 12:49 PM
Last Post: zkajdan
  Inexpected reboot during watching youtube video regivanx 1 3,414 10-19-2024, 06:02 AM
  (xorg) Video driver? falken 2 4,596 07-03-2024, 12:01 PM
Last Post: falken
  Manjaro Sway Theme Broken Eighty8 1 4,002 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,509 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,864 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 3,268 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,091 12-13-2023, 07:22 PM
Last Post: trillobite
