I haven't figured out to have have working sleep/suspend/hibernation yet. On version 20.02 KDE Plasma.
Also, curious on if the trackpad and keybinding firmware updates for pbp will be added into Manjaro ARM directly, or if we should manually install them.
There's a package for updating the keyboard, which I think is Ayufan's script.
pinebook-pro-keyboard-updater
Noob here...
Wanted to try Manjaro XFCE on my Pinebook so put an SD card in and "installed" 20.02. Works OK but it's running from the SD card.
How do I install it to the main 125 Gb memory?
(I'm confused about uBoot, emmc, etc.)
Anybody using dual monitors with Manjaro?
I have an external monitor connected through a USB-C adapter and this works fine with default sesame OS.
However, on Manjaro, it just mirrors the displays. It seems to think only one display is connected.
Manjaro has a separate emmc installer. mirroring is likely configurable. what program are you using to configure?
It just booted from the SD card. I'll have to see if I can find the emmc installer. However I don't have emmc, just the stock 125 gb mmc.
Using the Manjaro settings display manager.
(03-07-2020, 08:06 PM)mspohr Wrote: It just booted from the SD card. I'll have to see if I can find the emmc installer. However I don't have emmc, just the stock 125 gb mmc.
https://osdn.net/projects/manjaro-arm/st...e/20.02.1/
You can install emmc-installer img from this link. All you have to do it flash the img on the sd card, boot from that sd card and select the mmc partition when it runs the emmc-installer. It will flash the img from sd to emmc and then you can just reboot with sdcard removed from the pbp.
This will install Manjaro on eMMC and get you to the OEM installer screen to create user and password.
Manjaro ARM Team.
Thanks for this info. I'll try that.
However, the problems with the display may mean that I can't use this distro. Won't recognize second display connected to USB-C adapter and it insists that my internal display is 1.9k x 1.1k giving me a fuzzy screen. No way to change this with the Settings/Display.
(USB-C display adapter works just fine with open sesame default distro.)
Umm - the internal display is native Full-HD AKA 1920x1080 so info describing as "1.9k x 1.1k" would be a rounding version of Full HD - absolutely correct.
When the external display is mirroring the internal one and can be set to Full-HD also then that will be the same resolution.
I did notice that on the default fbturbo display drivers it was only possible to mirror the display, with mesa-git (aka panfrost) there were more graphics options but i'm not using that for other reasons.
Just did the updates to the system and now things are really dark, can’t read a thing... Might have to plug the power in.... Hope that fixes it!
(03-13-2020, 07:45 PM)crocky Wrote: Just did the updates to the system and now things are really dark, can’t read a thing... Might have to plug the power in.... Hope that fixes it!
That did not do any good...
The capital M that first appears on the screen is bright for a split second then it goes very dull.. At the login screen it is very faint and I can’t read it...  Huh
crocky
  Boot Order in Pinebook Pro food 12 16,058 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,010 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,550 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,950 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,442 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,463 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,697 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 114,603 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,251 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,390 03-31-2024, 10:11 AM
Last Post: u974615
