Multi Display on Manjaro KDE
Has anyone experienced problems connecting an external displays to their PBP in KDE?  Mine just mirrors the desktop and I don't see any options to extend it or change the resolution.  Is there any applications I can install on Manjaro to make configuration of the second (or third) display easy?
Thanks,
Karl
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
I guess it's safe to say that you are using XFCE spin with fbturbo? (fbturbo for this effect / xfce because it's more prominent to keep fbturbo on it compared to KDE spin).
For whatever reason, when using fbturbo the external display setup should prepared in `xorg.conf` . I've managed to find only scant and half-working solutions from Raspberry Pi threads which use fbturbo to little success.
Multi-screen setup should work as usual (or as usual as it can with some resolution weirdness) if go the Panfrost route.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
(02-14-2020, 05:48 PM)PakoSt Wrote: Multi-screen setup should work as usual (or as usual as it can with some resolution weirdness) if go the Panfrost route.
For multi-screen setup, I moved from xfce fbturbo to xfce panfrost. Now, I have working multi-screen, but my kernel does not seem to like it too much. It constantly logs:
Feb 18 09:44:24 manjaro kernel: Purging 622592 bytes
Feb 18 09:44:24 manjaro kernel: Purging 544768 bytes
Feb 18 09:44:24 manjaro kernel: Purging 524288 bytes
Feb 18 09:44:24 manjaro kernel: Purging 528384 bytes
Feb 18 09:44:24 manjaro kernel: Purging 593920 bytes
Feb 18 09:44:24 manjaro kernel: Purging 651264 bytes
Feb 18 09:44:25 manjaro kernel: Purging 2170880 bytes
Feb 18 09:44:29 manjaro kernel: panfrost_gem_shrinker_scan: 13 callbacks suppressed
Feb 18 09:44:29 manjaro kernel: Purging 6434816 bytes
Feb 18 09:44:29 manjaro kernel: Purging 983040 bytes
Feb 18 09:44:29 manjaro kernel: Purging 3190784 bytes
Feb 18 09:44:29 manjaro kernel: Purging 688128 bytes
Feb 18 09:44:29 manjaro kernel: Purging 2150400 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2097152 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2752512 bytes
Feb 18 09:44:30 manjaro kernel: Purging 561152 bytes
Feb 18 09:44:30 manjaro kernel: Purging 2396160 bytes
Feb 18 09:44:30 manjaro kernel: Purging 610304 bytes
Feb 18 09:46:57 manjaro kernel: panfrost_gem_shrinker_scan: 13 callbacks suppressed
Feb 18 09:46:57 manjaro kernel: Purging 524288 bytes
Feb 18 09:46:57 manjaro kernel: Purging 536576 bytes
I'm just looking to setup an external display with ease. Cloning the desktop is not what I need. I seems like this is not an ideal laptop for presentations, unless you use a cloned screen.
I got it to work now, but one of my usb-c dongles is not very reliable. Sometimes it connects, sometimes it doesn't. Can the usb-c video output drive 2 1080p external screens since it supports 4k?
I switched to the mesa-git (panfrost) from fbturbo.
(02-25-2020, 07:57 AM)binholz Wrote: I got it to work now, but one of my usb-c dongles is not very reliable.  Sometimes it connects, sometimes it doesn't.  Can the usb-c video output drive 2 1080p external screens since it supports 4k?
Cannot drive 2 1080p external screen even supports 4K
you might consider: the 5.6 git branch has some significant dts changes which have improved hdmi handling for me on debian. also not sure if rockchip/dptx.bin is built into the kernel for manjaro.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,321 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,874 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,994 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,946 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,458 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,823 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,992 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,156 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,335 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,156 11-14-2023, 10:57 AM
Last Post: trifleneurotic
