I haven't updated yet and I think I will wait until the storm passes on Arch Arm side of the qt libs (maybe on Tuesday or Wednesday -must resist Syu)
On the bright side, this swarm of updates brought a nice fix. Telegram no longer crashes when viewing animated stickers with it's newest version 1.9.9-1 that was created on 2020.01.30.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
(01-25-2020, 03:18 PM)xmixahlx Wrote: suspend / resume is a known problem with tsys's patched mainline kernel.
if you have skills in this area please feel welcome to fix this!
I found it's fixed in the code commit of tsys on sleep issue released yesterday and suspend/resume working nicely now.
It's still cost 30% battery during the sleep of one night.
Whatever happened before and after the qt libs were updated, it reverted the behavior of Telegram-desktop - crashes again when it sees a sticker.
The solution kindly shared by @Icenowy  is still needed.
Here is a Telegram-desktop package using that method: https://drive.google.com/open?id=1kQ0rHT...V3u7DN3nQ7
PS: @icenowy are you the same user? Smile
i rebuilt a 5.5 kernel on debian sid arm64 and can confirm suspend works *better*. for instance, power connection doesn't wake. will test suspend + battery tonight.
I am not sure where I should post this ... possibly better on a Manjaro forum?
I installed the latest Manjaro, and it's updates a week or so ago, and love it .... lots of customization for the desktop, menus, etc.
I was intrigued with a package called notes-tree.  I tried installing from packman, and got an error:
curl: (22) The requested URL returned error: 404
==> ERROR: Failure while downloading https://bitbucket.org/baltic/notestree/d...1.0.tar.xz
    Aborting...
As the version was theoretically 1.1, I edited the PKGBUILD file to reflect ver 1.1, and, of course got a checksum error:
==> Making package: notes-tree 1.1-2 (Thu 06 Feb 2020 10:49:57 AM EST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
  -> Downloading notes-tree-1.1.tar.xz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100  405k  100  405k    0     0   435k      0 --:--:-- --:--:-- --:--:-- 1902k
==> Validating source files with sha256sums...
    notes-tree-1.1.tar.xz ... FAILED
==> ERROR: One or more files did not pass the validity check!
I got the same error from going to the download site and manually downloading/cuncompressing and attempting to install manually.
There appears to be a version number issue/typo somewhere?
Thanks in advance .... or point me to the right direction for follow up.
Dennis Hoshield
PBPro/ANSI/Manjaro
@dhosh you can either:
- replace the checksum with the one from the file you are expecting (sha265sum <file_name> )
- skip that checksum
The checksums are used to verify if the file was downloaded correctly.
Keeping pkgrel higher than the available on the repos, will let you keep your version without reinstalling or adding to ignored packages
Most things on my PBP Manjaro install work well.  Kudus to Manjaro!
I would like to make a small database, and already have LibreOffice installed, and could use Base.  It requires JRE, however, and I've not found one that will install without failing on dependencies.  Any suggestions?
Dennis Hoshield
PBPro/ANSI/Manjaro
Use OpenJDK 11 or OpenJDK13.
If you want to use JetBrains products like Intellij IDEA, PyCharm or Clion - use the versions from the AUR.
If you see Intellij version from 2018 - regenerate your pacman mirrors and sync again.
Strit removed those old versions (which rely on jdk 8 that's broken on aarch64 for whatever reason) some time ago.
Very good! The regenerating the mirrors must have done it, as I had tried the OpenJDK 11 and another, before, but was getting dwpendanxy errors... Where they weren't found and couldn't be installed. Just installed (didn't see OpenJDK 13 .... But this should work!
Thanks!
Dennis Hoshield
PBPro/ANSI/Manjaro
I'm still hoping for hibernate (suspend to disk) to start working. I've tried my own hand at it and even tried compiling the BSP kernel to try and get it working. Unfortunately, trying to use the BSP kernel lead me to a non-booting system (good thing I had backups), so I still haven't gotten there. I've gotten it to 'hibernate', but resuming doesn't seem to work. Anyone else have any work-arounds I could use (aside from using s2idle and the likes)?
  Boot Order in Pinebook Pro food 12 16,389 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,213 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,656 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,072 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,537 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,598 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,831 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 115,732 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,331 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,550 03-31-2024, 10:11 AM
Last Post: u974615
