Thank you everyone for all the work on this! I just got my pinebook and Manjaro has worked really great for me. Everything is smooth and seems to work better than even the default Mate image.
The only problem I have is with suspend/wake. I only get a blank screen after a lid close. I would love to do anything I can to help resolve the issue.
suspend / resume is a known problem with tsys's patched mainline kernel.
if you have skills in this area please feel welcome to fix this!
Flashed Manjaro to a SD card, loving it. Thank you!
Thumbs Up
Hey y'all
I've been toying with Manjaro ARM all day and I am digging it. I'm booting it from a MicroSD which is probably why it is a little slower at opening applications overall than stock Debian but it is much smoother.
Other than the known suspend issue I have noticed that:
- When pausing or resuming a YouTube video the speakers pop, like a static discharge or something. It also happened a couple times after I closed the YouTube tab and came back to this forum to post this very reply. It isn't a very big deal but something I felt I should mention.
I am really enamored with my PBPro and will continue distro hopping but Manjaro ARM has just set a very high standard.
Cheers!
Just some guy
(01-26-2020, 01:53 AM)Bushrod Wrote: Hey y'all
Cheers!
Thank you for trying Manjaro and testing it for us. About the Static discharge issue, we're aware of it and it is something to do with kernel side dtb changes. We're waiting for the kernel dev's to look into it, I agree it is not a big deal but it will be fixed soon (hopefully).
Quote:Manjaro ARM has just set a very high standard.
Thank you once again for appreciating what we do at Manjaro Arm Team.
Manjaro ARM Team.
I have also been using Manjaro ARM since receiving my Pinebook Pro and am overjoyed with it. It has the best hardware support and addresses the most quirks of this device currently, which is great. I had never used Manjaro or Arch in the past and I've found the experience wholly positive.
Exciting times ahead, thanks for all the hard work!
Hi all. New user of Manjaro ARM on the PineBook Pro.
Is anyone using the USB Ethernet dongle from the Pine64 store? I cannot get mine to work. It lights up ok. But all my attempts to bring up the eth0 interface fail.
Using "ip a" or "ip link" shows it as DOWN. The system loads a r8152 module for the dongle. I was hoping the interface would activate and dhcp would give it an address. Giving eth0 a static address does work, but it is not able to connect to internet through the dongle yet.
Question: Will Network Manager - handle both Wifi and USB Ethernet dongle?
Any suggestions on how to get the dongle working?
(01-31-2020, 03:15 PM)S265 Wrote: Hi all. New user of Manjaro ARM on the PineBook Pro.
This has been resolved by closer examination of the network cabling. The Dongle is now working.
for those using the KDE version, updates to the Qt libraries should be avoided.
See this topic on the Manjaro forum: https://forum.manjaro.org/t/new-qt5-es2-...shoutherif
Kernel Updates
I installed a small program and that triggered pacman to update the whole system including the kernel. During this process, I realized kernel updates could be handled better:
Kernel updates delete the old modules and so the newly installed modules don't match the running kernel. The running kernel can't now load any further modules. I believe modules should never be deleted by the system (or at least in a much smarter way).
  Boot Order in Pinebook Pro food 12 19,239 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,562 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,263 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,691 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,401 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,501 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,688 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 124,129 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,783 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,505 03-31-2024, 10:11 AM
Last Post: u974615
