How to install Skype on PBP?
When I try to download and install i get the following:
rock@Debian-Desktop:~/Downloads$ sudo dpkg -i skypeforlinux-64.deb
Selecting previously unselected package skypeforlinux:amd64.
(Reading database ... 131101 files and directories currently installed.)
Preparing to unpack skypeforlinux-64.deb ...
Unpacking skypeforlinux:amd64 (8.55.0.141) ...
dpkg: dependency problems prevent configuration of skypeforlinux:amd64:
skypeforlinux:amd64 depends on libasound2 (>= 1.0.16).
skypeforlinux:amd64 depends on libatk-bridge2.0-0 (>= 2.5.3).
skypeforlinux:amd64 depends on libatk1.0-0 (>= 2.2.0).
skypeforlinux:amd64 depends on libatspi2.0-0 (>= 2.9.90).
skypeforlinux:amd64 depends on libc6 (>= 2.17).
skypeforlinux:amd64 depends on libcairo2 (>= 1.6.0).
skypeforlinux:amd64 depends on libcups2 (>= 1.4.0).
skypeforlinux:amd64 depends on libexpat1 (>= 2.0.1).
skypeforlinux:amd64 depends on libgcc1 (>= 1:3.0).
skypeforlinux:amd64 depends on libgdk-pixbuf2.0-0 (>= 2.22.0).
skypeforlinux:amd64 depends on libglib2.0-0 (>= 2.35.8).
skypeforlinux:amd64 depends on libgtk-3-0 (>= 3.9.10).
skypeforlinux:amd64 depends on libnspr4 (>= 2:4.9-2~).
skypeforlinux:amd64 depends on libnss3 (>= 2:3.22).
skypeforlinux:amd64 depends on libpango-1.0-0 (>= 1.14.0).
skypeforlinux:amd64 depends on libpangocairo-1.0-0 (>= 1.14.0).
skypeforlinux:amd64 depends on libsecret-1-0 (>= 0.18).
skypeforlinux:amd64 depends on libuuid1 (>= 2.16).
skypeforlinux:amd64 depends on libx11-6 (>= 2:1.4.99.1).
skypeforlinux:amd64 depends on libx11-xcb1.
skypeforlinux:amd64 depends on libxcb1 (>= 1.6).
skypeforlinux:amd64 depends on libxcomposite1 (>= 1:0.3-1).
skypeforlinux:amd64 depends on libxcursor1 (>> 1.1.2).
skypeforlinux:amd64 depends on libxdamage1 (>= 1:1.1).
skypeforlinux:amd64 depends on libxext6.
skypeforlinux:amd64 depends on libxfixes3 (>= 1:5.0).
skypeforlinux:amd64 depends on libxi6 (>= 2:1.2.99.4).
skypeforlinux:amd64 depends on libxrandr2 (>= 2:1.2.99.3).
skypeforlinux:amd64 depends on libxrender1.
skypeforlinux:amd64 depends on libxss1.
skypeforlinux:amd64 depends on libxtst6.
skypeforlinux:amd64 depends on apt-transport-https.
skypeforlinux:amd64 depends on libfontconfig1 (>= 2.11.0).
skypeforlinux:amd64 depends on libdbus-1-3 (>= 1.6.18).
skypeforlinux:amd64 depends on libstdc++6 (>= 4.8.1).
dpkg: error processing package skypeforlinux:amd64 (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
Errors were encountered while processing:
skypeforlinux:amd64
Uh, that appears to be trying to download AMD64 files. Pinebook Pros use ARMv8 / ARM 64bit.
Arwen Evenstar
Princess of Rivendale
And if you're using the default Debian, you're going to need to be looking for the armhf version of the package(s).
I don't think there is an arm64 armhf build of skype, but this may work on Chromium: https://chrome.google.com/webstore/detai...fpfgnpldfl
(01-20-2020, 01:06 PM)tophneal Wrote: And if you're using the default Debian, you're going to need to be looking for the armhf version of the package(s).
Yes I'm using default everything. I won't change that as I want to remain on what Pine64 devs setup by default.
That said, I plan to use this laptop daily but fore light apps. What I need are:
Skype
Dropbox (sync app)
Termius
Possible with default setup? If not, any workarounds?
Skype
Dropbox (sync app)
Termius
Hard to say for sure, as I personally switched to Chromium/Manjaro, but if you can't find those for Linux, there is an Android image you could use.
(01-20-2020, 01:10 PM)Luke Wrote: I don't think there is an arm64 armhf build of skype, but this may work on Chromium: https://chrome.google.com/webstore/detai...fpfgnpldfl
Thanks, works. Anyway to launch at boot or when opening Chromium?
I'm using Remmina for now as I cannot get Termius installed.
Dropbox, no luck. I can access the files via website but really would like to save locally when editing files/code. So need to gett dropbox installed.
Chromium apps should be visible the same as other apps, and appear in your Menu. You should also be able to set it as a Startup Application.
(01-21-2020, 07:10 AM)tophneal Wrote: Chromium apps should be visible the same as other apps, and appear in your Menu. You should also be able to set it as a Startup Application.
It does not show up. Remember I'm using the recommended Chromium Browser extension. Not the Chromium OS.
It should still show up. I use Chromium in my Manjaro install, and the apps I install are available through my menu, and can be added to the dock. If they don't appear on their own, or are just hard too find (sometimes the app category is WAY off) you also go to the Extensions page in Chromium, right click on SKype, and select Create Shortcut. That will put it in the Menu and make it available to put into the dock/panel.
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 16,104 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,690 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 5,641 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,726 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  install debian on pbp jsch 7 10,756 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 6,006 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 8,841 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 4,621 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 10,246 11-24-2022, 10:24 AM
  How can I install Debian? ImmyChan 1 5,508 10-19-2022, 03:09 AM
Last Post: alpopa
