Incompatible NVMe SSD - Silicon Power P34A60
Exclamation
Not sure if there is an Incompatible SSD list, but if there is this one doesnt work:
https://www.silicon-power.com/web/product-P34A60
I bought the 256GB variant, it doesnt show up at all in DMESG and GParted fails to locate it. nvme list returns no NVMe drives conencted.
I've installed it in a USB3 caddy which proves the SSD isnt faulty and it connects as /dev/sda.
I know the NVMe adapter and the PBP are ok as I threw money at the problem and purchased a Toshiba OCZ RC100 240GB (on the Wiki as a confirmed working SSD) which is working fine.
So if nayone is thinking of a Silicon Power A60 NVMe SSD, don't it doesnt work in the PBP.
I
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
aww
one of my favorites in the 2.5" sata SSD's
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-07-2020, 04:55 PM)gandlers Wrote: Not sure if there is an Incompatible SSD list, but if there is this one doesnt work:
Any idea why it doesn't work?
I couldn't find any power specs on that page.
I was curious and tried to track down xases where it was being used on a linux system,  and didn't find any.  I wonder whether there is a problem with the rockchip_pcie driver or pcie drivers in general.  Since it is a dramless device, if I understand the specs correctly  it seems that power would not be an issue,  but I do wonder about timing.
Also from the specs on the referenced page:
  • System Requirement
  • Computer with M.2 slots supporting PCIe interface and one of the following operating systems: Windows 8.1 or Windows 10
Sorry I have no idea why it didnt work.
No apparent difference to DMESG output after a boot with it installed and one without.
My linux knowledge is basic to say the least so I have no idea what the problem could be.
(01-09-2020, 11:22 AM)gandlers Wrote: Sorry I have no idea why it didnt work.
Regardless, whether you know why, SSD failures can go here:
https://wiki.pine64.org/index.php/Pinebo...patibility
(01-09-2020, 01:00 PM)zaius Wrote: Regardless, whether you know why, SSD failures can go here:
Hint taken... Big Grin
  NVMe drives not detected mattpenn 18 30,613 12-24-2024, 08:54 PM
  NVMe reukiodo 0 2,908 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,338 11-17-2024, 04:24 AM
Last Post: reukiodo
  Pinebook Pro on Debian 12 Power Issue u974615 1 4,811 03-13-2024, 10:46 AM
Last Post: u974615
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,566 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,297 11-28-2022, 12:56 PM
Last Post: dachalife
  Increasing the maximum power draw dsimic 15 33,762 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 29,305 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 14,694 09-26-2022, 12:17 AM
Last Post: jonasd
  NVme intall usage? tkudog 2 6,268 03-04-2022, 01:29 AM
Last Post: Tazdevl
