No POWER after installing Manjaro on microsd
Hi guys,
I hoping to get some assistance with my pinebook pro which no longer powers on.
I've been using the factory installed debian and thought i'd give manjaro a go.
I used the Manjaro-ARM-kde-plasma-pbpro-19.12.img.xz image and put it on my micro sd via etcher. After booting up on the micro sd the manjaro install continued (i chose user name, keyboard layout etc) then it rebooted
Since then I can't get my pinebook to power on with either the micro sd in or out (I was at least hoping debian would run without the micro sd).
I came across this thread but want to be I believe my situation is different (I thought I didn't write to eMMC)???
-update 1- since writing this post, I have been able to get the power light on (flashing, but nothing on screen).
-update 2- i've plugged in power and it boots now via debian. I will test further and report back
Many thanks
George
hmmm... i feel like an idiot but when I plugged in the charger cable I was able to boot again in debian and also complete the install of manjaro on the micro sd???
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,406 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,017 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not power on (or only 1 in 10 times) zkajdan 2 3,917 02-27-2025, 12:10 PM
Last Post: zkajdan
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,111 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,002 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,509 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,864 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,091 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,251 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,371 12-07-2023, 03:11 PM
