0.9.14 Release: Ubuntu 18.04 with Mate & LXDE Desktop
#41
(10-23-2019, 08:48 AM)Luke Wrote: kwim_x11 or wayland?
I think the first one, I did not install wayland packages.
Odoslané z ONEPLUS A5010 pomocou Tapatalku
#42
Yea, of course, I just looked at the photo you sent in the chat - thanks.
For reference:
[Image: B93TmUu.png]
#43
So yesterday I tried upgrading to 19.10, I enabled ayufan's disco repo as well as his pre-releases repo.
Update went smooth, system started and worked, including wifi. The acceleration stopped working,
[Image: unknown.png?width=571&height=467]
Will try today upgrading from Mate without changing additional repos and then to install KDE.
#44
I tried this distro today via Micro-SD and can't get by the password.....Forgive me for being dense, but what have I missed, Thanks! :-)
#45
Ok, what exactly have you done and what was the result? You could not login after installing, or after booting SD card? First password is rock64, then you should change it.
#46
(10-24-2019, 11:38 AM)Wizzard Wrote: Ok, what exactly have you done and what was the result? You could not login after installing, or after booting SD card? First password is rock64, then you should change it.
Made up a micro SD from the image. Booted first to the OEM OS, installed the SD card to be sure it is recognized, reboot, get to the password and nothing works (no password I could think of, i.e. rock, root, rock64, etc). That help? :-)
#47
ok, so you entered the default password "rock64" and then? Then you should enter it once more and then the new password twice.
#48
(10-24-2019, 12:03 PM)Wizzard Wrote: ok, so you entered the default password "rock64" and then? Then you should enter it once more and then the new password twice.
Didn't work but I'll try again tonight....Many Thanks! :-)
#49
PERFECT!! Thank You!! :-)
#50
UPDATE: Ok, I rebooted again and find that "rock64" won't work. Any idea why?
  Gentoo on Pinebook Pro RELEASE jannik2099 54 159,263 12-08-2023, 11:25 PM
  Armbian 22.02 release announcement TRS-80 22 29,807 04-01-2023, 03:19 PM
Last Post: TRS-80
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 1,986 02-16-2023, 10:58 AM
Last Post: cowsay
  Install the DDE desktop environment wangyukunshan 0 3,904 12-23-2021, 06:51 PM
Last Post: wangyukunshan
  Desktop environment of Ubuntukylin 20.04 wangyukunshan 3 7,590 10-26-2021, 08:07 PM
  After update in Ubuntu bionic mate system crashed Wawe 2 7,117 04-18-2021, 04:52 AM
Last Post: Wawe
  OpenMandriva to release ARM builds for PineBook Pro and Pi ludix 11 19,889 03-02-2021, 07:06 PM
Last Post: BronzeBeard
  Ubuntu Installation on PBP narinderpal10 5 11,938 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,264 12-15-2020, 01:53 AM
Last Post: BryanF
Information [Development Release] Fedora 32/CentOS 8 Pinebook Pro Images wideawake 12 24,621 12-10-2020, 10:06 AM
Last Post: pieter085
