[Development Release] Fedora 32/CentOS 8 Pinebook Pro Images
Information
After my recent posts on various social media platforms there was interested showed in test driving some of the images I have been working on. I have now decided that I have roughed out enough of an image to make available to the public. I plan on building and deploying a custom repo with my RPMs I have built with various Pinebook Pro related fixes and tweaks in the near future. Install and expand the partition as usual.
Note: This is an early `pre-release` if you will. INSTALL TO SD ONLY. I only have a ANSI based Pinebook Pro so that is the only device this has been tested on.
Fedora 32 Workstation:
MD5 Checksum: 5b39417f1c24716c822834c80ad59b5f
Download Link
CentOS 8 Server with GUI:
MD5 Checksum: ce1da2f8355e31217dacd72f2baf702c
Download Link
Known Issues:
CentOS: Screen brightness function key not working, works in Fedora  :?
Fedora: Shutdown PackageKit Daemon takes 1.5mins, thought I fixed this...
Fine One? Report It!
To Do:
Fix kernel packing to more closely resemble Fedora/CentOS Official RPMs
Fix Plymouth boot screen?
Please if you find any bugs, tweaks, have comments, or suggestions feel free to drop them here!
-Mike
Thank you for the image. I installed it earlier today. I like the way it goes into an OEM sort of setup. After installing I found it needed ~700MB of updates which seems like a lot for a new fresh image.
It has been running very nicely through out the day. All the special function keys do what they are labeled to do. Sound works quite well. Power management and usage is good as well. I have not encountered any issues with this.
Thanks again
bill
(08-04-2020, 05:26 PM)wove Wrote: Thank you for the image. I installed it earlier today. I like the way it goes into an OEM sort of setup. After installing I found it needed ~700MB of updates which seems like a lot for a new fresh image.
Thanks again
bill
You are very welcome. Thank you for trying it out and posting your feedback! I had a tough time debating whether to update the packages or leave at the base release. I will do a dnf update on the next images before release. Smile
Awesome! I should also mention while it says development release it is super stable and I have optimized all the bits I could. Even got boot time down to ~40 seconds or so.
-Mike
I'm using the Fedora image on an sd card. I needed an image to play with SELinux. I've not seen any issues yet. I have very little experience with Gnome 3, but I'm surprised how well its running on the PBP so far. I'll post if I find anything not working as it should, but so far so good.
Thanks for the effort, this image is quite usable!
A few bugs and quibbles
I don't like the way gdm is setup, session chooser in bottom right
and only after user is selected
I could never get right click to register, in any DE
dndragora never worked, python3 often hung
I couldn't get xfce to work, always hung
icewm was about the best alternative to gnome
dnd seems to want to refresh on slightest provocation,
must have reloaded 6 times
I never did try rpm, I guess I should have
Do you have md5sums for these images? I have tried writing both of them to two different cards, and I can't get either to boot. Either I have corrupt downloads or I am overlooking something in the image writing. I've been using:
xzcat centos8-202008-ARMDevelopers.img.xz | dd of=/dev/mmcblk0 conv=fsync bs=1m status=progress
Am I missing something there?
Thanks,
Jon
(08-14-2020, 10:33 PM)hotsaucegrocer Wrote: Do you have md5sums for these images? I have tried writing both of them to two different cards, and I can't get either to boot. Either I have corrupt downloads or I am overlooking something in the image writing. I've been using:
Thanks,
Jon
Hi Jon,
I have updated the first post with the checksums, thanks for suggesting! Check your download but everything sounds fine. Does your main OS on your EMMC boot fine?
(08-09-2020, 06:10 PM)trm Wrote: I'm using the Fedora image on an sd card. I needed an image to play with SELinux. I've not seen any issues yet. I have very little experience with Gnome 3, but I'm surprised how well its running on the PBP so far. I'll post if I find anything not working as it should, but so far so good.
Were you able to get SELinux working on the image? Something is escaping me even after recompiling support into the kernel.
-Mike
I'm not at all sure with a compressed image that you need to bother with md5sum,,
if a zip or xz is damaged, it will error out, For an iso, yes, it is worthwhile to check
All zip programs have a test function, nearly always -t, example ,, xz -t <image>
You may know, if it says nothing, all is well, image is OK
I used fedora image, mrfixit on emmc (and so, mrfixit uboot)
(08-14-2020, 10:48 PM)wdt Wrote: I'm not at all sure with a compressed image that you need to bother with md5sum,,
Right, I am working on debugging the official fedora image. Lots of trials and tribulations but it's starting to make sense. Big Grin
Hi wideawake and other
I can't find your image anywhere. the URL is empty Sad
Andreas
  Boot Order in Pinebook Pro food 12 17,852 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,937 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,979 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,302 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,567 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,143 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 19,813 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 17,101 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,091 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,251 12-11-2023, 03:47 AM
Last Post: calinb
