Problems making the boot sd card (android)
I'm excited to mess with mine today at work(boss will be out) since I can't at home. I have Google fiber at home and everything is gigabit, which meant my pine wouldn't communicate with the network.
(02-04-2016, 05:26 AM)SkairkrohBule Wrote:
(02-04-2016, 05:16 AM)Tarjei85 Wrote: When I got home I tested the sd-card on my windows computer and i had 116Gb capacity and 32Kb used (119Gb before the process, so something has happend)
But i did not get the request to format the sd-card. Weird. Guess I just have to waituntil I get my Pine and see then.
That sounds about right. The Android OS is about 1.6GB on one partition, then there's a small boot partition as well. The remaining space is the space you can install all your apps and stuff onto.
If you use the PhoenixCard app, it automatically formats the card before burning the OS image.
Thank you for clearing things for me.
Can I copy files to the partition that shows up when i plug in the sdcard to my computer before I boot the first time? and what will the folder layout be on that partition?
Was hoping to put all my APK's and OBB/data files from my tab on the sdcard so it is a easy job copying data files to the right folder and installing the APKs when I recieve the Pine.
*Cant wait till March to get the board* Cry
Can't see why that wouldn't work, in theory. Though like I said, in Windows, for me at least, it doesn't detect the Android install (just says the card is not formatted, would I like to format now?). Only in Ubuntu did it show me all the partitions and stuff.
Hi
I burned android image to the sd via phoenix, and dont ask me why but had to click twice to get it done right. The first try failed after some writing, so be sure to have a look to the log...
(02-04-2016, 03:15 PM)drag00n Wrote: Hi
The same happened to me. Had to start the burning process twice. But after the second try it completed as it should.
Now I just have to wait until my Pine arrive (first I need the survey email to specify the model and amount of boards I want) so that I can start messing around with this.
I have ordered the card, when ordering the Pine. Has anyone had issues with these?
Edd
Sad PINETAB-V doesn't boot. FEC 1 2,647 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 5,339 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 2,545 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 3,204 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 4,033 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 2,938 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  How to boot from SD card on pinebook pro linux123 3 9,323 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 5,022 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 3,320 10-18-2020, 01:41 PM
Last Post: toiny
  micro sd card won't insert Samuel Venable 2 6,338 09-01-2020, 12:15 AM
Last Post: Samuel Venable
