Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)]
Big Grin
Was playing around with the idea of making a SuperMario themed casing for my Pine.
The casing will be made in 3mm acrylic and the overall dimmensions of it will be 135x135x135mm.
I was not able to attach image, but if you follow the link under you can see the "prototype" of the case from my OneDrive album.
The album can be found here...
(The last image is side by side my Lumia 925 as reference to the size of the casing)
Because of the design there is ALOT of room for "shields" and addons to the Pine.
Needless to say this is going to be used as a gaming console...
UPDATE 27. April 2016:
             New STL file is uploaded to my Google Drive account.
             Newest update is raising the cutouts 5mm to make sure there is room for the soldering points underneath the Pine
             The file can be found HERE!
(02-11-2016, 09:17 AM)Tarjei85 Wrote: Was playing around with the idea of making a SuperMario themed casing for my Pine.
Nice!
Very cubey
And Marioesque Wink
I am working on some CAD drawings of the casing, but they are done by hand because my computer is bust so I cant do them digitally. I will post them here when they are done. Smile
Using the CAD Touch PRO app for my tablet I did manage to make the CAD drawings digitally.
All the drawings is in 1:1 but they are not marked with dimmensions.
Tese CADs are in 2D so if anyone want to make some 3D CADs out of it you are welcome.
The CAD drawings (and preview images) are found here at my oneDrive account.
I am still working on the drawings, but there is just some small cosmetic changes to be made. I will keep you posted on the progress....
EDIT 14. FEB 2016 17:18 : Updated drawings. Added some details to "top", "bottom" and "back".
EDIT 14. FEB 2016 23:50 : Updated drawings. Added feet to "bottom"-drawing.
EDIT 15. FEB 2016 00:19 : Updated drawings. Added detailed "logo"-drawing.
that's pretty cool! Good Job
(02-18-2016, 08:12 PM)carb1a4h Wrote: that's pretty cool!  Good Job
Thank you. New and updated drawings will be placed on the onedrive-folder in a day or two (with all the current measurements).
I am still waiting for a complete blueprint of the board so that I can place the cutouts for all the ports.
EDIT 19. Feb. 2016 12:20 :
  • Updated drawings/pictures of all views. Added measurements on almost all drawings.
  • Added support for 120*120mm fan mounted on the top-plate.
  • Added multiple possibilities for external antenna for WiFi and Bluetooth.
  • Modified feet to have room for rubber/silicone paddings (Ø 8mm).
  • Added "made in" announcement underneath.
EDIT 22. Feb 2016 22:15:
  • Added 3D model to the oneDrive account
[Image: nydelig.png?psid=1]
[Image: vakkert.png?psid=1]
All creds to my brother Skjalg for the great renderings. Thank you!
Thumbs Up
(02-22-2016, 01:16 PM)Tarjei85 Wrote: EDIT 22. Feb 2016 22:15:
Thanks to my brother for the 3D renderings.
Yes, very nice indeed!
Is this able to be 3d printed or where can I could get this?
TechieManny   Shy
Photo Weatherproof case build ltorsini 12 40,900 07-07-2026, 07:01 PM
Last Post: ltorsini
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,142 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 20,006 02-22-2019, 03:24 AM
Last Post: GaryFunk
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,414 10-12-2018, 03:08 PM
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,582 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 29,981 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 16,361 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 140,828 03-30-2017, 11:36 AM
Last Post: Luke
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 38,781 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 22,145 10-24-2016, 08:18 AM
Last Post: killor
