[Star64] Help needed in understanding Yocto and U-boot build process
Hi everybody,
I'm new to building Linux and related components for embedded systems. I found the work that @Fishwaldo has done with `meta-pine64`, however I'm having trouble visualising the entire process. I'd like an ELI5 for a few topics so I can try building my own images.
My questions are (as of now):
1. How did you figure out the U-boot partitions required? The U-boot documentation (https://docs.u-boot.org/en/latest/board/...l#flashing) uses 4KiB for the SPL and 8KiB for U-boot + OpenSBI. However, the JH7110 user-guide (https://doc-en.rvspace.org/VisionFive2/D...oot_UG.pdf) doesn't seem to mention this (or does it? Not sure if I missed something important). How did you know?
2. If I understand correctly, Fishwaldo patched the Linux Kernel tree in a new branch with the OEM drivers from StarFive? Then, he created the layer on top of Poky and the other base layers from Openembedded? Why is it that he is forced to use the Linux 5.1xx kernel instead of the new 6.1xx kernel? Did StarFive mention this limitation somewhere that I missed it?
Thanks for reading through! I really appreciate the help - I would like to be part of the effort to take RISC-V forward, and I want to be able to build my own images for the Star64 alongside the SOEdge module as a replacement for Coral.ai's TPUs.
Thanks!
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 22 22,381 10-19-2026, 12:27 PM
  Star64: All listed distros don't boot tantamount 0 1,345 05-08-2026, 08:56 AM
Last Post: tantamount
Sad PINETAB-V doesn't boot. FEC 1 4,194 08-23-2025, 02:58 PM
Last Post: Woazboat
  Star64: GPU firmware loading on Armbian Der Geist der Maschine 15 23,823 05-06-2025, 11:44 AM
  Case for Star64? garyd 0 2,510 04-22-2025, 12:41 PM
Last Post: garyd
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 7,163 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  Star64 JH7110 (slarm64, riscv64) mara 2 5,530 10-09-2023, 03:43 AM
  Star64: jtag debugging? bluepill 1 4,892 09-20-2023, 08:26 AM
Last Post: bwooster0
  Star64: 4GB on 8GB boards Der Geist der Maschine 4 7,986 07-27-2023, 12:32 AM
Last Post: balbes150
  Star64: SATA Der Geist der Maschine 1 3,771 07-26-2023, 12:35 PM
Last Post: Gladox114
