Star64: All listed distros don't boot
Here an overview of what Star64 distros work or don't.
TL;DR: None listed in the wiki boot
Irradium 3.8, kernel 6.12:
 Doesn't boot. The power light stays green forever, no HDMI signal.
Irradium 3.8, kernel 7.0:
DietPi Trixie:
Armbian:
 They dropped the Star64 some time ago.
NixOS v2023.11.26:
 This one doesn't decompress: "unexpected end of file"
NixOS 23.11.20230827:
NuttX RTOS:
What does boot:
1. I still have an ancient copy of Armbian from when it did support the Star64, which does boot (non-graphical).
2. I see that Fishwaldo's old images from 2023 are still available here: https://pine64.my-ho.st:8443/
Thus I think the "Software releases" section should be updated to remove the entries for the distros that don't even boot.
Of Fishwaldo's 3 images (version 2.1), I get the following results:
  • The minimal distro does not boot. I get the green light that never blinks blue. This is a pity because text-only could be useful.
  • The Weston distro boots and provides a fast GUI, however it doesn't provide anything else, like a menu or a way to launch apps or settings.
  • The Plasma distro boots and provides a fast but more laggy GUI, but it does almost fully work.
Just now, with the Fishwaldo Plasma distro I was able to do the following which is pretty impressive:
  1. Boot up and log in as pine64 (password pine64).
  2. Set up Wifi, which works fine.
  3. Run Firefox, which is somewhat slow but it works.
  4. Download a FOSS program, compile it and run it.
  5. Su as root (password pine64) and run "apt update" but there are no new packages. (e.g. GCC is version 11 but the current version is 14).
  6. Install ffmpeg. This runs fine, however ffplay crashes with a segmentation fault.
  7. Mount a USB thumb drive from the command line (it wasn't seen by Dolphin file manager).
  8. Convert an MP3 to WAV and play it with `aplay`, which sounded like there was interference.
Regarding Weston, when I tried to force a text-only startup (systemctl set-default multi-user), this was ignored.
I think for some people, the text-only startup option could be necessary for projects.
  Star64 Irradium (based on crux linux) riscv64, aarch64 mara 22 21,715 10-19-2026, 12:27 PM
Sad PINETAB-V doesn't boot. FEC 1 4,039 08-23-2025, 02:58 PM
Last Post: Woazboat
  Star64: GPU firmware loading on Armbian Der Geist der Maschine 15 23,298 05-06-2025, 11:44 AM
  Case for Star64? garyd 0 2,411 04-22-2025, 12:41 PM
Last Post: garyd
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,975 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,653 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Star64 JH7110 (slarm64, riscv64) mara 2 5,365 10-09-2023, 03:43 AM
  Star64: jtag debugging? bluepill 1 4,824 09-20-2023, 08:26 AM
Last Post: bwooster0
  Star64: 4GB on 8GB boards Der Geist der Maschine 4 7,848 07-27-2023, 12:32 AM
Last Post: balbes150
  Star64: SATA Der Geist der Maschine 1 3,686 07-26-2023, 12:35 PM
Last Post: Gladox114
