Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold
Question
What is causing this and how can I fix it?
After an event which caused my Pinecil V2 to stop working with a near-0V 3V3 rail until i desoldered the shorted USB C PD chip, my temperature readings jump to over 400°C. I am suspecting a voltage spike from a dodgy PSU to be the cause of this event, though i am not certian. The jumpy temperature reading only happens when the iron is heating up, not while in standby/off mode.
From what I can tell from the schematic, documentation and sourcecode, the Pinecil switches between heating and using the heater as a dodgy thermocouple. I am suspecting that another component got affected by the event and either gets stuck or take a longer-than-usual time to switch or settle. I have tried swapping the OP-Amp that is responible for reading the tip voltage, but to no avail, so i swapped the original one back in. I am currently going through the sourcecode to try and increase the measuring time and/or the time waited after switching off the heater power and before measureing the temperature.
This seems promising so far: https://github.com/Ralim/IronOS/blob/993...Q.cpp#L154
Does anyone else have a different idea to what could be the cause of this issue?
  pinecil v2 dosent negotiate power moses 0 1,672 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 1,108 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,542 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,772 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,464 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,880 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,398 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,256 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,181 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 7,189 05-15-2025, 10:41 AM
Last Post: dreieck
