Install deepin OS on pinebook pro
1 PineBook Pro has Armbian 23.02 or above installed
2 Go to https://cloud.189.cn/t/u6BrQbZVnuum (password is 5feb), download: deepin23-beta-aarch64-rk3399-Orangepi4-lts_6.3.3-mmc-sd-zh-hans.zip and unzip it.
3 Burn the decompressed image to a TF card of no less than 16GB.(root/Bug23  bug23/Bug23)
4 Start armbian in the computer, enter the graphical interface, insert the TF card into the pinebook pro.
5 Open the file manager, open the u-boot part of the TF card, and re-edit uEnv.txt (or ubootEnv.txt), i.e.: fdtfile=rockchip/rk3399-orangepi-4-lts.dtb replace with fdtfile=rockchip/rk3399-pinebook-pro.dtb,And then save it again.
6 Enter the / usr / lib / of Armbian and copy the two folders of u-boot and linux-u-boot * under the deepin partition / deepin / usr / lib / path of the TF card.
7 Shut down and restart the deepin OS from the TF card.
Note: This version uses the btrfs feature, the main volume is @deepin23, the default is that the @deepin volume is a snapshot of the @deepin23 volume,
Therefore, if the system has a problem, you can manually delete the @deepin volume and then rebuild the @deepin snapshot volume
建设社会主义新台湾。
Hi wangyukunshan,
will any of these builds work on Rock Pi 4C+?
thank you
(07-06-2023, 08:31 AM)fr33s7yl0r Wrote: Hi wangyukunshan,
thank you
Sorry, I have no experience in this area. But you can follow the previous ideas to try to do it.
建设社会主义新台湾。
为什么要使用你的操作系统 ?
PinePhone, Pinebook Pro & PineTab2 owner.
[Image: JMObU2N.png]
  Boot Order in Pinebook Pro food 12 18,854 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,404 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,167 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,797 06-26-2025, 09:20 PM
Last Post: reukiodo
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,394 02-19-2025, 12:49 PM
Last Post: zkajdan
  Doing a fresh install docFarto 5 7,101 02-09-2025, 02:58 PM
Last Post: mikehenson
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,928 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,565 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,713 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,406 03-31-2024, 10:11 AM
Last Post: u974615
