Partial boot after installing Manjaro on emmc
Thumbs Up
Hi, the problem is solved.
I installed Tow Boot on the emmc which solved the problem.
However, when Tow Boot is installed on the SPI, I have exactly the same problem as with U-Boot: the system does not detect the encrypted partition on the SD card, it does not detect the SD card at all (no /dev/mmcblk1), booting is impossible and I get into an emergency shell.
Procedure:
On another computer, download the latest version of Tow Boot at https://github.com/Tow-Boot/Tow-Boot/releases. Choose the pinebookPro version.
Assume the latest version is pine64-pinebookPro-2021.10-005.tar.xz
$ wget https://github.com/Tow-Boot/Tow-Boot/releases/download/release-2021.10-005/pine64-pinebookPro-2021.10-005.tar.xz # download archive $ tar xvf pine64-pinebookPro-2021.10-005.tar.xz # unzip $ cd pine64-pinebookPro-2021.10-005 $ cp shared.disk-image.img [your-usb-stick-location] $ sudo -s # dd if=spi.installer.img of=[your-SDcard-location-in-/dev/] bs=1M status=progress
Then, I plugged the USB key into the faulty computer, and I started it with the encrypted SDcard to arrive at the emergency shell.
Perhaps due to the abnormal boot, I was unable to use dd with the options given in the documentation.
On the emergency shell,
# dd if=shared.disk-image.img of=/dev/mmcblk2 bs=1M oflag=direct,sync status=progress # /dev/mmcblk2 is internal emmc memory.
returns an error.
So I used the command:
# dd if=shared.disk-image.img of=/dev/mmcblk2 bs=1M oflag=direct conv=fsync
Source.
What worked.
Then I replaced the encrypted SDcard with the Tow Boot SDcard containing spi.installer.img, rebooted and overwritten the SPI memory.
Finally, I replaced the Tow Boot SDcard with the encrypted SDcard, and when I restarted, everything was working normally.
I tried to install Tow Boot on SPI memory, but as I said, Tow Boot on SPI does not detect the encrypted SDcard.
I haven't tested unencrypted system boot on emmc with Tow Boot on SPI. As Tow Boot works on the emmc, I leave it as is.
Thanks for your help, wdt and KC9UDX!
Pinebook Pro, standard config (Manjaro)
FYI (and anyone else) the problem with the command,,,
dd does not work with csv (comma separated values) only <parmeter>=<value>
gotta wonder how (emmc) mbr persisted
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,460 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,784 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,957 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 3,147 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,929 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,953 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 13,067 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,665 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 6,060 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,802 09-04-2024, 10:35 AM
