Pinephone Freeze
Search for "flipping frames bug" in this forum, there are several reports of it. It appears to be a GPU power management issue. It can be worked around by udev rules reducing the maximum GPU frequency and disabling GPU power management.
E.g., this snippet:
https://forum.pine64.org/showthread.php?...#pid115469
also has the workarounds for the "flipping frames bug", not just for modem bugs.
(01-23-2023, 08:51 PM)Westslope Wrote: I am using Manjaro with Phosh and have a problem where the GUI will appear to freeze, well not quite, more like the input is no longer responsive. The GUI then becomes as what I would describe as "jittery", the last touch screen input toggles/untoggles rapidly, if using the onscreen keypad, or if scrolling, it shifts by a pixel or so and jumps back and forth. If I press the side power button to shutoff the screen and try to turn it back on, the backlight turns on but the screen remains black. The only way I've found to bypass this is to plug in a USB-C to USB-A adapter and hook up an external keyboard. This allows me to CTRL+ALT+F2 to a terminal login prompt and use that to 'systemctl restart phosh' which restarts it and brings back the lockscreen.
I'm still trying to find the exact error messages that would be associated with the problem, but I'll see if I can find them.
sounds like what i have been dealing for MONTHS! (i shall get a life...some day). btw, you didn't tell your hardware version? hint, https://wiki.pine64.org/wiki/PinePhone#H..._revisions .
check this https://forum.pine64.org/showthread.php?tid=17771 .
videos:
https://barrelmem.s3.eu-north-1.amazonaw...ingbug.mp4
https://barrelmem.s3.eu-north-1.amazonaw...232537.mp4
https://barrelmem.s3.eu-north-1.amazonaw...202728.mp4
https://barrelmem.s3.eu-north-1.amazonaw...222922.mp4
https://barrelmem.s3.eu-north-1.amazonaw...135843.mp4
bug report for pmos (hint, fastforward to the end):
https://gitlab.com/postmarketOS/pmaports/-/issues/805
this bug can be bypassed, however i still wonder why all pinephones do not affect in same manner. this bug is perfect daily driver killer, even though battery life is already quite a killer.
few things. some cases there are more frames than two. the bug does not crash whole system, only u.i.. ttyescape and ssh is possible to do something. however, some cases system crashes totally, so only hard reset is only option.
if postmarketos then "dmesg" reveals logs. this command only show if system is still running, not for previous boot. others could use "journalctl", hint: "journalctl -r".
Actually, before I applied your udev rules that make the bug go away, I had found that, at least for me, touch input was not actually dead in "flipping frames bug" mode: holding the power button for 3 seconds, then tapping where "Restart" should normally appear, successfully triggered a reboot.
(01-24-2023, 09:50 AM)Kevin Kofler Wrote: Actually, before I applied your udev rules that make the bug go away, I had found that, at least for me, touch input was not actually dead in "flipping frames bug" mode: holding the power button for 3 seconds, then tapping where "Restart" should normally appear, successfully triggered a reboot.
assuming that sytem hasn't totally freezed, user interface still works. display is just stuck with few frames, and updates same frames all time.
plasma may funtion little differently than phosh.
videos:
Yep, that's it. I have the 1.2b version.
  New PinePhone user issues greenpineuser 8 8,499 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,775 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,089 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,830 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,102 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 7,959 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 9,065 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone craches after each call neithan76 2 4,402 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 54,639 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 7,680 05-09-2022, 08:29 AM
Last Post: ragreenburg
