Pinephone with KDE plasma - Battery drain when phone is not used
I have pinephone (KDE plasma mobile)
it drains battery very quickly (6 to 8 hours)
even if I don't use phone and it is in standby mode
display is turning off after 1 minute as set in power settings
but I think that some system process is not turning of when phone is not used
and it drains power from battery.
How can i check which program is still runing
discharging battery ? is there any program for checking system activity ?
Your power settings are to only turn the display off, not suspend? Then it is not surprising that the battery is drained very quickly. Make sure you keep suspend enabled (it is enabled by default) if you want lower power consumption in standby.
Also, whatever you do, it is always a good idea to leave the PinePhone plugged in overnight and only plug it out when you actually leave home. (Yes, it probably makes the battery fail faster. But we are still taking about years, and a compatible replacement battery is cheap and widely available.)
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 22,254 02-20-2026, 12:16 PM
Last Post: krissprat73
  New PinePhone user issues greenpineuser 8 8,666 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 20,033 10-04-2024, 12:01 AM
Last Post: spazz
  link for supported pinephone os manjharo et all penguins_rule 3 4,938 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,220 04-02-2024, 11:52 AM
  New phone, KDE desktop settings reset on reboot zzb0 2 6,531 10-15-2023, 10:19 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,543 10-02-2023, 05:07 AM
Last Post: Uturn
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 3,198 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,534 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  new PinePhone upgrade issue WhiteHexagon 5 8,082 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
