6/22 run of PBPs - is reimaging eMMC with new OS possible still?
@elitegamercody
This is the one that I used: https://github.com/manjaro-arm/generic-i....08.img.xz
It booted immediately for me and all of the hardware I've tried has been functional.
Hope this helps!
(08-25-2022, 07:46 AM)Crewchief Wrote: @elitegamercody
Hope this helps!
My device refuses to boot from this image. I have no idea why. Are there any other people with this experience?
I can only boot from 22.04/22.06 pinebook-pro specific Manjaro images for the bootloader, but I can't boot from the 22.08 generic. The 22.04/22.06 UBoot works but then I get a kernel panic.
Can we please confirm with certainty that Pinebooks Pro are being shipped with code in the SPI "ROM"?
:wq
(08-27-2022, 05:45 AM)KC9UDX Wrote: Can we please confirm with certainty that Pinebooks Pro are being shipped with code in the SPI "ROM"?
Yes, they are.
I reflashed Tow-Boot to mine - I can now boot from USB. using the manjaro-arm-installer script, I now boot loop to the
"ERROR: device:'PARTUUID=0b... not found. Skipping fsck.
:: mounting '<identical not found device>' on real root
mount: /new_root: can't find <identical not found device>"
So manjaro-arm-installer isn't working either.
Is there an internal tool used to create factory images of Manjaro for these?
I can confirm the current batch of PBP’s is okay. I redid mine with Kali and with some work, everything is usable.
PinePhone, Pinebook Pro & PineTab2 owner.
Do either of you actually know that there was code in the SPI before you overwrote it? I suspect there was not. This is the way all PBPs up till this point have been. If I'm right, we need to ignore the kerfuffle about the PPP. It doesn't apply to the PBP.
Edit: I did find mine to be blank, as I expected.
:wq
(08-27-2022, 01:40 PM)dachalife Wrote: I can confirm the current batch of PBP’s is okay. I redid mine with Kali and with some work, everything is usable.
How did you get WiFi to work? Copy all firmware from Manjaro?
Gesendet von meinem RMX3085 mit Tapatalk
https://gitlab.com/kalilinux/build-scrip...issues/286
That is the quickest way, credit goes to someone else; I didn't post it here first.
Is there any way to remove the UUID issue? Every image I boot is asking for a UUID that doesn't exist. Don't understand why I have to constantly chase this.
YES, use tune2fs (-U) to change UUID to what it is looking for
man tune2fs
don't forget to update fstab and maybe extlinux.conf (I don't know about boot.scr)
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,248 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,404 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,587 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 13,682 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 3,236 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 3,570 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 9,088 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 29,373 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 11,422 08-18-2022, 11:47 AM
Last Post: Bemo
