Debian emmc installer
I'm trying to install Debian on the emmc. I've tried building an image from the firmware and partition images here https://deb.debian.org/debian/dists/bull...rd-images/ and here https://d-i.debian.org/daily-images/arm6...rd-images/.
In both cases no network interfaces are detected at all and it appears wifi drivers are missing, meaning I can't complete the install.
Is it expected that those images don't contain the driver? (I thought the netboot spin included non-free?). What is the best way of getting that driver? Is there another image I should be using?
take a look on https://forum.pine64.org/showthread.php?tid=16862, maybe this gives an idea what needs to be done in your case
(08-15-2022, 10:09 AM)jsch Wrote: take a look on https://forum.pine64.org/showthread.php?tid=16862, maybe this gives an idea what needs to be done in your case
Thanks. I was hoping to avoid needing to buy a USB eth adapter but looks like it's the easiest (only?) way for now.
You could install the system without the wifi driver, use a usb-stick to copy the necessary packages over once debian is installed on the pinebook. My pinephone came with the dock, hence I chose this approach.
Generally speaking, Armbian is going to be far ahead of upstream (vanilla Debian) on any sort of SBC type device (including PBP) because Arm/SBC world is so different from x86.
Having said that, there is currently an issue with installing Armbian to eMMC. Not sure what's up with that, pretty sure it used to work. I hope to have my new PBP in my hands in a few more days, then I can maybe try and see what's happening. In the meantime, it should run well off SD card.
Cheers,
TRS-80
Protocols, not Platforms
Right tried installing with a USB ethernet adapter (worked on the roght USB port only not the left), seema like everything installs fine but at the very end it fails to reboot and doesn't boot thereafter. I'm trying the guided partitioning with encrypted LVM, could that be an issue or is that expected to work fine?
Actually looks like it might be unrelated to luks after all, the same thing seems to happen with an unencrypted install
  Debian on Pinebook Pro u974615 7 1,009 03-31-2024, 10:11 AM
Last Post: u974615
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  install debian on pbp jsch 7 4,029 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,407 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,972 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,051 07-15-2023, 02:58 PM
Last Post: u974615
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,496 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,848 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 869 12-19-2022, 01:01 PM
Last Post: Besouro
