Failure to install gcc
I am not that well versed in how the packaging works in Manjaro. But it feels rather feeble.
So far I am unable to install gcc as it requires another package which the system is unable to find.
[hvdk@pinebook ~]$ sudo pacman -S gcc
afhankelijkheden oplossen...
zoeken naar conflicterende pakketten...
Pakketten (5) binutils-2.34-2  elfutils-0.180-1  libmicrohttpd-0.9.70-3  libmpc-1.1.0-2
              gcc-9.3.0-1
Totale Download Grootte:          0,19 MiB
Totale Geïnstalleerde Grootte:  143,29 MiB
:: Doorgaan met de installatie? [J/n] j
:: Pakketten ophalen...
fout:kan het bestand 'libmicrohttpd-0.9.70-3-aarch64.pkg.tar.xz' niet ophalen van mirror.netzspielplatz.de : The requested URL returned error: 404
fout:kan het bestand 'libmicrohttpd-0.9.70-3-aarch64.pkg.tar.xz' niet ophalen van mirror.ufro.cl : The requested URL returned error: 404
To be honest it feels rather inmature.
Is there a soultion except installing a more mature distribution on the pinebook Pro?
Regards, Hugo.
You may have too old package listings or bad mirrors.
Run:
sudo pacman-mirrors -f5
to update the mirror list, then
sudo pacman -Syyu
To update the package list and the packages, too. After that you can install the latest software.
Remember to update the package list often because most mirrors don't keep older packages around.
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 347 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 4,059 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 1,595 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,070 07-15-2023, 02:58 PM
Last Post: u974615
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,510 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,319 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 3,779 11-24-2022, 10:24 AM
  How can I install Debian? ImmyChan 1 2,051 10-19-2022, 03:09 AM
Last Post: alpopa
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,100 09-05-2022, 12:00 PM
Last Post: petersen77
  Install of ArchARM on latest pbp batch tallfrye 0 690 08-22-2022, 02:36 PM
Last Post: tallfrye
