No EDID data for built in screen, PHY missing?
I'm running my Pinebook Pro with Manjaro ARM v20.04 (testing) and the GNOME desktop. I'm delighted to say that Gnome works beautifully except that it is unable to load a color profile and the 'Night Light' feature does not actually change the screen's white balance.
I think these two issues are linked. Loading a color profile relies on the colord daemon. In the journal, I see many instances of the following message from colord:
colord[1613]: failed to get edid data: EDID length is too small
I also see these messages, and I suspect they are related to Gnome's Night Light:
gsd-color[1446]: failed to get edid: unable to get EDID for output
gsd-color[1446]: unable to get EDID for xrandr-eDP-1: unable to get EDID for output
Indeed, checking
/sys/devices/platform/display-subsystem/drm/card0/card0-eDP-1/edid
shows it is empty.
I also see this message in the journal as the kernel initializes:
kernel: rockchip-dp ff970000.edp: no DP phy configured
I'm wondering if this means the current 5.6.0-2 kernel is unable to access the EDID data for the built in panel or (worse) whether the hardware to do this is missing. Can anyone from Pine confirm whether or not the PBP's built in screen is able to provide EDID data or not?
One last thing, I've tried connecting an external monitor via DP and in this case, I do see data in
/sys/devices/platform/display-subsystem/drm/card0/card0-DP-1/edid
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 14,829 06-26-2025, 09:20 PM
Last Post: reukiodo
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,394 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 5,191 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,578 05-31-2024, 09:42 AM
Last Post: SynthGal
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 2,747 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 8,435 04-01-2023, 03:22 PM
Last Post: TRS-80
  Missing A Few Programs on PostmarketOS on PB Pro publiclewdness 0 1,979 03-06-2023, 11:33 PM
Last Post: publiclewdness
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 1,729 02-16-2023, 10:58 AM
Last Post: cowsay
  Archlinux - missing firmware for wifi adapter RudderDuck 9 13,005 11-07-2022, 04:56 PM
Last Post: wgahnagl
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 4,639 09-23-2022, 08:37 PM
Last Post: computerc
