(01-21-2020, 08:57 AM)tophneal Wrote:(01-21-2020, 08:49 AM)james64 Wrote:(01-21-2020, 07:10 AM)tophneal Wrote: Chromium apps should be visible the same as other apps, and appear in your Menu. You should also be able to set it as a Startup Application.
It does not show up. Remember I'm using the recommended Chromium Browser extension. Not the Chromium OS.
It should still show up. I use Chromium in my Manjaro install, and the apps I install are available through my menu, and can be added to the dock. If they don't appear on their own, or are just hard too find (sometimes the app category is WAY off) you also go to the Extensions page in Chromium, right click on SKype, and select Create Shortcut. That will put it in the Menu and make it available to put into the dock/panel.
see attached.
Screenshot at 2020-01-22 21-11-01.png (Size: 125.61 KB / Downloads: 470)
