How to install Skype on PBP?
(01-21-2020, 08:57 AM)tophneal Wrote:
(01-21-2020, 08:49 AM)james64 Wrote:
(01-21-2020, 07:10 AM)tophneal Wrote: Chromium apps should be visible the same as other apps, and appear in your Menu. You should also be able to set it as a Startup Application.
It does not show up. Remember I'm using the recommended Chromium Browser extension. Not the Chromium OS.
It should still show up. I use Chromium in my Manjaro install, and the apps I install are available through my menu, and can be added to the dock. If they don't appear on their own, or are just hard too find (sometimes the app category is WAY off) you also go to the Extensions page in Chromium, right click on SKype, and select Create Shortcut. That will put it in the Menu and make it available to put into the dock/panel.
see attached.
.png   Screenshot at 2020-01-22 21-11-01.png (Size: 125.61 KB / Downloads: 469)
Perhaps it's a DE specific package that makes them available. I believe you have it installed, but I'm curious why it doesn't show in you apps menu.
(01-22-2020, 07:16 PM)tophneal Wrote: Perhaps it's a DE specific package that makes them available. I believe you have it installed, but I'm curious why it doesn't show in you apps menu.
because it's a Chrome extension and not an application.
If that's the case, I'd love to know why all of my Chrome extensions/apps are available in the app menu of my Manjaro Gnome3 install. Even the Text and IRC client apps for ChromiumOS show up until I turn them off on the extensions page.
As a quick example, I'm attaching a screenshot that shows Chrome Remote Desktop (no longer stand alone, Chrome extension only) in the extensions page, and my panel/dock.
.png   Screenshot from 2020-01-23 14-14-17.png (Size: 415.63 KB / Downloads: 383)
not sure either. Now i'm getting crashes every few hours. Only change today was to install keyboard/touchpad update as per wiki. arrrg
(01-20-2020, 01:10 PM)Luke Wrote: I don't think there is an arm64 armhf build of skype, but this may work on Chromium: https://chrome.google.com/webstore/detai...fpfgnpldfl
Doesn’t seem to work - I get a “audio and video not supported by your browser” error bot in web version and as a plugin but works fine in Firefox. Anybody know why this can be? (This is Debian)
Several months later, I'm using a Skype Pidgin plugin.
Are you able to get video chat working with pidgin?
#19
No, Skype4Pidgin does not support video or audio chat at all.
I also researched this a bit, and while using https://web.skype.com with Chromium is no issue at all for text chat, there seems to be no way to make it work with video/audio chat.
Edit: See message below, with useragent spoofing in Firefox Skype Web seems to work.
Maybe in the future there might be a way to use the Android version with Anbox, but right now Anbox does not support passing through the camera either AFAIK.
#20
Is it possible to install Skype via flatpak or snap for aarch64?
:: I can confirm that Skype video and messaging is working in Firefox with the Skype add-on that bypasses the browser support. Use web.Skype.com
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 413 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 4,206 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 1,708 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,223 07-15-2023, 02:58 PM
Last Post: u974615
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,600 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,387 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 3,915 11-24-2022, 10:24 AM
  How can I install Debian? ImmyChan 1 2,116 10-19-2022, 03:09 AM
Last Post: alpopa
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,193 09-05-2022, 12:00 PM
Last Post: petersen77
  Install of ArchARM on latest pbp batch tallfrye 0 714 08-22-2022, 02:36 PM
Last Post: tallfrye
