how to install jmtpfs ?
I got a new phone with android 10 and now my pinebook cannot see it when I plug in with usb cable.  I did a little searching and several pages mentions that I would need jmtpfs (https://github.com/JasonFerrara/jmtpfs).  I tried modifying the build file to add aarch64 and still cannot build for manjaro.  Not really sure what my next steps would be.  Is there a way to know what is holding up the package build? some dependency that also needs to be built for aarch64?
For anyone interested in what was going on with my phone: I could see the device in file explorer but not access any storage:
No storage media found. Make sure your device is unlocked and has MTP enabled in its USB connection settings.
you may need to try editing to PKGBUILD of libmtp (jmtpfs dependency) to include aarch64 https://archlinux.org/packages/?q=libmtp
(07-26-2021, 06:37 AM)tophneal Wrote: you may need to try editing to PKGBUILD of libmtp (jmtpfs dependency) to include aarch64 https://archlinux.org/packages/?q=libmtp
I already have fuse and libmtp installed ( and these are the only dependencies I see).  Im getting an error from yay about config.guess not being able to tell what my cpu is.  I guess I can follow the instructions and alert the maintainer with the specs, but I figured there might be something I could do locally.
If no one here has built jmtpfs, how are you guys plugging your Android 10+ phones into the pinebook?  I never had this issue before updating to Android 10 and 11.
if you try again, add your output from yay with the error. may be able to help someone point you to what's causing the problem.
(08-02-2021, 07:11 AM)tophneal Wrote: if you try again, add your output from yay with the error. may be able to help someone point you to what's causing the problem.
added aarch64 to arch in the PKGBUILD and get this error:
Quote:==> Starting build()...
checking build system type... ./config.guess: unable to guess system type
This script, last modified 2009-11-20, has failed to recognize
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
 http://git.savannah.gnu.org/gitweb/?p=co...ss;hb=HEAD
and
 http://git.savannah.gnu.org/gitweb/?p=co...ub;hb=HEAD
If the version you run (./config.guess) is already up to date, please
send the following data and any information you think might be
pertinent to <config-patches@gnu.org> in order to provide the needed
information to handle your system.
config.guess timestamp = 2009-11-20
uname -m = aarch64
uname -r = 5.13.4-1-MANJARO-ARM
uname -s = Linux
uname -v = #1 SMP Tue Jul 20 18:40:45 UTC 2021
/usr/bin/uname -p = unknown
/bin/uname -X     =
hostinfo               =
/bin/universe          =
/usr/bin/arch -k       =
/bin/arch              =
/usr/bin/oslevel       =
/usr/convex/getsysinfo =
UNAME_MACHINE = aarch64
UNAME_RELEASE = 5.13.4-1-MANJARO-ARM
UNAME_SYSTEM  = Linux
UNAME_VERSION = #1 SMP Tue Jul 20 18:40:45 UTC 2021
configure: error: cannot guess build type; you must specify one
==> ERROR: A failure occurred in build().
   Aborting...
error making: jmtpfs
Looks like you may want to build this without the assitance of yay https://stackoverflow.com/questions/4810...pe-failure
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 347 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 4,060 11-22-2023, 04:22 PM
Last Post: TRS-80
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,084 07-15-2023, 02:58 PM
Last Post: u974615
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,513 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,321 02-14-2023, 12:49 PM
Last Post: Valiance
  Tow Boot install help Paulie420 7 3,784 11-24-2022, 10:24 AM
  How can I install Debian? ImmyChan 1 2,052 10-19-2022, 03:09 AM
Last Post: alpopa
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,102 09-05-2022, 12:00 PM
Last Post: petersen77
  Install of ArchARM on latest pbp batch tallfrye 0 694 08-22-2022, 02:36 PM
Last Post: tallfrye
