Manjaro stuck on boot
Hey
I'd like to switch from Debian to Manjaro. I tried to flash the KDE and the XFCE eMMC installer as well as the sd card versions to sd cards. The eMMC version always gets stuck in the startup screen. Same things happens after installing the sd card versions onto the sd cards. Is there anyone having the same problem and knowing a solution?
I experience this as well, I tried switching to TTY2 from the boot logo (ctrl + alt + F2) and it just put me into the installer. If not, try switching between different TTYs (aforementioned combo with F1, F2, F3, etc up to 8 or so).
(01-04-2020, 10:40 AM)whadduppp Wrote: Hey
Can't speak to the KDE installer, but for the XFCE installer this is a known bug. I believe the current working solution is to press ESC after 30s.
  Boot Order in Pinebook Pro food 12 17,895 05-25-2026, 08:28 AM
Last Post: finmark
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,413 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,026 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,121 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,314 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 4,007 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,514 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,872 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,107 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,275 12-11-2023, 03:47 AM
Last Post: calinb
