(11-28-2019, 08:26 AM)richfm Wrote:
(11-27-2019, 08:44 PM)bcnaz Wrote: The PBP antenna,  not the router.
I didn't know the PBP had a wifi antenna. If that is not working properly, then I paid for a defective device and want a working replacement.
I tested the wifi reception on my 3 laptops, the PBP running ubuntu mate, an ASUS laptop running ubuntu mate, and a netbook running ubuntu mate. My house is 1 floor, 2 bedroom, wood frame house with plaster walls. I took each laptop from the room with the gateway to the opposite end of the house and noted the wifi signal strength. The ASUS laptop's signal was steady at 65 mb/s in every room. The Toshiba netbook was steady at 52 mb/s in every room. The PBP varied from 72 to 65 mb/s in the room with the gateway down to 6 mb/s in other rooms! This tells me the wifi hardware in the PBP is defective. I've tried several things to improve page loading on the PBP like increasing the CPU speed to maximum and flashing several OSs to MMC. The signal strength so was still too slow.
So far the Pine Info team has been slow to make suggestions and their suggestions (reboot router and install default Debian) have not made any difference.
richfm:
Other Posts have mentioned checking the antenna connection at the motherboard.
I believe the actual antenna is behind your screen.
*(The fact that it works well close to your router,   shows it does function,   ---   but loses reception quickly as you move away)
* I HOPE that helps
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
richfm:
* I HOPE that helps
Thanks, bcnaz. I have not found any information in the forums about the antenna. I don't see a way to search for certain posts. I found the wifi antenna location at https://wiki.pine64.org/index.php?title=...nal_Layout but have no idea what to do with the antenna. Would someone refer me to these  posts.
(11-28-2019, 11:05 AM)richfm Wrote: ...
@richfm, There is an antenna wire coming from the location of the antenna to the main system board. Our comments are to make sure that wire is plugged into the the antenna connector on the main system board. If the antenna cable is loose or completely dis-connected, you may get some WiFi signal, but not very strong. (Notice I say may, this is highly computer design, location and orientation of the device dependant.)
Next, there is a known issue with WiFi power saving. Later versions of various OSes turn off WiFi power saving. So, try a SD card of another OS.
Some details are in a WiFi troubleshooting section of the Pinebook Pro Wiki;
Wiki - Pinebook Pro - WiFi issues
Obviously it's not complete, it's very early days. The first 2 issues aren't yours, you have some functionality. Whence we find someone who actually had a loose or dis-connected WiFi antenna cable and that fixes their problem, I'll add that to the WiFI Issues troubleshooting page.
Arwen Evenstar
Princess of Rivendale
(11-26-2019, 05:13 AM)Soul_Hacker Wrote: i had chromium fixed in less than a few minutes but that got me thinking about firefox/iceweasel, which i still cannot get to run.
I have firefox working perfectly, no crash and everything works. I only had to do a small sound fix.
Download Firefox from http://ports.ubuntu.com/pool/main/f/fire..._armhf.deb
Run in terminal dpkg -i firefox_70.0.1+build1-0ubuntu0.16.04.1_armhf.deb (it didn't work double-clicking it).
Sound fix: Open about:config, create the variable media.cubeb.backend and set it to pulse. Restart the browser.
(11-28-2019, 08:38 PM)forkbomb9 Wrote: Sound fix: Open about:config, create the variable media.cubeb.backend and set it to pulse. Restart the browser.
Thanks for the tip. I've upgraded my pinebook pro to Debian Buster, but had the problem that some video's on youtube doesn't play sound. Your tip fixes this  Smile
How did you update to Buster?
(11-29-2019, 01:00 PM)Luke Wrote: How did you update to Buster?
My first failed attempt was:
 - edit /etc/apt/sources.list
 - apt update
 - apt upgrade or apt dist-upgrade (don't remember exactly)
After that, the system was broken.
So, I've used dd to restore the original mrfixit Debian.
After that, I've done something like:
 - apt update
 - apt install package
I've repeated to install package by package, fixed conflicts by hand (don't remember al the details), until everything was upgraded.
Note, that I don't recommend this. It was fun to do Wink , but for example my webcam doesn't work (don't need it) and I'm sure there are other things broken too.
I've also installed dwm, so that I have a "desktop environment" that suits me best...
 - apt update
 - apt update
You should also hold back xorg as that is custom.
(11-29-2019, 02:55 PM)Luke Wrote: You should also hold back xorg as that is custom.
Thanks for the tip. I'll remember it when I'll break things again and start over from scratch  Wink
I opened the bottom of the PBP and compared the layout to the specifications picture on the wiki. It looked the same as the wiki photos. I checked the antenna connection after removing the tape. It seemed to be seated firmly. So I replaced the tape. I didn't touch anything else but screwed on the bottom panel.
Does anyone see anything wrong with the wifi antenna or the connections? I'm sending these pictures to the Pine Info team.
.jpg   20191130_091935_compress15.jpg (Size: 465.65 KB / Downloads: 329)
.jpg   20191130_092007_compress63.jpg (Size: 459.74 KB / Downloads: 318)
.jpg   20191130_092058_compress82.jpg (Size: 467.48 KB / Downloads: 274)
.jpg   20191130_092120_compress41.jpg (Size: 422.06 KB / Downloads: 299)
.jpg   20191130_093001_compress69.jpg (Size: 454.3 KB / Downloads: 293)
  looking to buy one pinebook pro (mainland China) duanduan 3 2,316 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 406 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 309 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 295 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 231 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 682 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 762 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,631 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,251 12-15-2023, 02:11 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,432 11-20-2023, 06:22 PM
Users browsing this thread: 8 Guest(s)
