Pinephone stuck on 'something went wrong' after update
Hi, I updated my Pinephone using these instructions https://wiki.pine64.org/wiki/PinePhone_U...structions
$ sudo pacman -Syu
after his command it tried to do an update abut after a few minutes of downloading different packages it crashed and now when I start up the phone there's a screen that says 'something went wrong' with only a logout button. If I press logout, the Manjaro UI shows for a split second before the phone loops back to the lock screen again. Any thoughts on how to fix this issue and get it back to a working state? Thanks
(03-06-2022, 01:21 PM)gofishus Wrote: Hi, I updated my Pinephone using these instructions https://wiki.pine64.org/wiki/PinePhone_U...structions
$ sudo pacman -Syu
Easiest would be if you just reflash, https://wiki.pine64.org/wiki/PinePhone_I...structions
  New PinePhone user issues greenpineuser 8 6,577 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 17,245 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,105 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 3,849 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 4,053 04-02-2024, 11:52 AM
  Using too much juice since last update Eugo 20 18,263 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 11,211 02-13-2024, 01:19 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 8,473 10-02-2023, 05:07 AM
Last Post: Uturn
  new PinePhone upgrade issue WhiteHexagon 5 6,648 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Latest update Eugo 21 21,416 03-09-2023, 05:27 AM
Last Post: Eugo
