PineTime - Navigation
How do you get the Navigation app in the watch to work. I am using InfitiTime 1.3.0 with GadgetBridge 0.59.1.  Also there is a heartrate feature in GadgetBridge, anybody knows how that works? Thanks in advance!
Nobody? Sad
I'm not sure if it's the navigation app or just notifications, but directions from Osmand do appear on the PineTime.
(08-29-2021, 06:28 AM)wibble Wrote: I'm not sure if it's the navigation app or just notifications, but directions from Osmand do appear on the PineTime.
Thanks, will try that...
@wibble I tried Osmand on my Samsung Note 9, no dice... :'(
Found out via InfiniTime at Github, "Puremaps with Amazfish. Nothing else."
https://github.com/JF002/InfiniTime/issues/385
That GitHub Issue is now closed. Still not working with OsmAnd. Dear person for whom it worked, how did you make it work and what versions of things are you running?
It was a few versions of Osmand, Gadgetbridge and InfiniTime ago, and a chance discovery while walking at night, so I didn't take notes. I hadn't used the PineTime much in an everyday setting before either. I wasn't expecting the watch to vibrate, and the small text wasn't much use while walking so after the first couple I ignored it. I think I was getting notifications rather than a specific navigation interface. It may depend on the Gadgetbridge and Osmand settings too. I don't think I changed anything much on Gadgetbridge but I usually turn off voice navigation in Osmand and may have changed other things at some point.
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,060 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,007 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,283 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,248 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,222 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,416 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,210 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,518 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,372 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,898 01-31-2024, 11:57 AM
Last Post: tynstar
