How do I clear all personal data from the pinetime smartwatch?
Depending on the firmware your PineTime is using and it's companion app, it looks like the best/easiest option is to use the companion app to reset the firmware to factory settings.
Do you mean to say that when I upgrade the firmware it will erase all user data?
I just upgraded it to infinitytime 1.14.0 yesterday (from 1.12.0
So, does that mean I am clear now?
not necessarily. if it was specifically presented as a firmware update and your settings are still in effect after the upgrade, then i'd say no. a firmware update and factory reset aren't usually the same thing.
what companion app are you using on your phone with the watch? We can look through it's documentation to find where the option to factory reset/clear any of your data from the watch.
Thank you.
I am using gadget bridge as my companion app
I'm getting this from GadgetBridge instructions for resetting a different watch (i don't have my own pinetime to refer to either) but it's worth a try: in gadgetbridge > settings > debug do you see a reset option?
Thank you. I found it, using it does not have any visible response from the device.
On the other hand, on further inspection, I am not sure if there is really all that much personal data stored to actually delete.
Does it actually store records of my steps and heart rate monitor results?
it connects via bluetooth. but not wifi. so it shouldn't be storing my wifi password.
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,579 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,423 11-01-2025, 05:55 PM
Last Post: euiccc2025
  setting data sync interval to Gadgetbridge dhdurgee 0 1,907 10-09-2025, 01:13 PM
Last Post: dhdurgee
  Migrating to PineTime from a Fitbit dhdurgee 0 4,534 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,473 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,500 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,732 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,962 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,739 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 3,079 01-31-2024, 11:57 AM
Last Post: tynstar
