setting data sync interval to Gadgetbridge
I now have my PineTime updated to the 1.15.0 firmware and resources by use of Gadgetbridge and ITD respectively.  It took me a while to get the resources updated as there was a patch needed to ITD and then I had to realize that the PineTime could only be paired with one of them at a time.  I also had a problem getting it to talk to Gadgetbridge again, requiring me to remove the initial device and add it again.
Gadgetbridge tells me that my PineTime is in control of the data syncing.  It seems to take a while before I see an update from the PineTime showing in Gadgetbridge.  I assume there is a setting somewhere to change how frequently data updates are sent to Gadgetbridge.  Where is that setting located?
Dave
  Unable to switch from Wasp-OS back to Inifinitime using GadgetBridge Bruce Kissinger 0 2,573 10-02-2024, 07:31 PM
Last Post: Bruce Kissinger
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,339 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,620 06-25-2024, 12:21 AM
Last Post: Amen
  Issues Connecting with GadgetBridge XOmniverse 1 4,253 06-04-2024, 02:45 PM
Last Post: bof
  Hardware Request: A screenless data collection wearable (like the Whoop) croisca 1 5,372 01-28-2023, 08:01 AM
Last Post: wibble
  [question] How does the step counter log data? arock 1 3,569 06-20-2022, 04:33 AM
Last Post: wibble
  Gadgetbridge vs RF Connect ronaldheld 2 5,650 03-30-2022, 06:14 AM
Last Post: danimations
  Pinetime won't reconnect to gadgetbridge after being disconnected for a while kelbot 9 17,436 10-02-2021, 08:59 AM
Last Post: wilsonjw
