Unable to switch from Wasp-OS back to Inifinitime using GadgetBridge
I have installed the latest version of Wasp-OS on a new PineTime watch, however I would like to switch back to Infinitime.  I installed Wasp-OS using the latest version of GadgetBridge (v 0.18.0) on an Android phone and the process was really simple.  However, I have run into problems trying to switch from Wasp-OS back to Infinitime.
The problem is that when I try to use GadgetBridge to install the Inifinitime Zip files, I get an error from GadgetBridge that states "FW/App Installer - Element cannot be installed".  GadgetBridge is successfully connected to the watch via BLE.  I've tried a number of different versions of the Zip files, but all return the same error.
Does anyone have advice for how to get past this?  Thank you in advance
  wasp-os status erikzoltan 6 7,699 08-07-2026, 05:15 AM
Last Post: cleansugar
  setting data sync interval to Gadgetbridge dhdurgee 0 1,810 10-09-2025, 01:13 PM
Last Post: dhdurgee
  Getting back Bluetooth chris.burmajster 0 2,260 03-24-2025, 06:26 PM
Last Post: chris.burmajster
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,773 06-25-2024, 12:21 AM
Last Post: Amen
  Issues Connecting with GadgetBridge XOmniverse 1 4,376 06-04-2024, 02:45 PM
Last Post: bof
  Unable to upgrade from 1.12 to 1.13 Avron 5 7,108 11-24-2023, 05:17 PM
Last Post: BrianPineFan
  Gadgetbridge vs RF Connect ronaldheld 2 5,713 03-30-2022, 06:14 AM
Last Post: danimations
  Pinetime won't reconnect to gadgetbridge after being disconnected for a while kelbot 9 17,620 10-02-2021, 08:59 AM
Last Post: wilsonjw
  Wasp-os editing main.py Mpoint 4 6,932 08-07-2021, 02:34 PM
Last Post: danielt
  Cheap way to secure back - elastic band?! andystratton 4 7,841 03-10-2021, 07:10 AM
Last Post: mfashby
