Open-Source Support for PineTime LTE (eSIM)
I would like to see a PineTime LTE version with eSIM support... if there is even an open-source/free software OS that can support this. From what I understand, Google has not open-sourced WearOS.
For some hardware, it is supported under GNU/Linux by this: https://linuxphoneapps.org/apps/eu.lucaweiss.lpa_gtk/. So something like postmarketOS with the AsteroidOS UI could support it. But, GNU/Linux requires several orders of magnitude more RAM than what the microcontroller-class SoC of the current PineTime includes. So it would need completely different hardware, not just added LTE modem and eSIM chips.
It is possible that the code could be ported to Infinitime or some other PineTime OS, but one would need to port not only the eSIM management code, but also the whole modem interface (ModemManager or ofono), and the result would probably also not fit in the current PineTime's memory.
you probably only need qmi/qrtr to compile estkme-group/lpac and could interface the lpad from outside via another device
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,232 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Migrating to PineTime from a Fitbit dhdurgee 0 4,354 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,312 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,298 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,501 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,362 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,654 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,473 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,950 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 3,875 10-14-2023, 04:12 PM
