Network stacks no longer works on PBP - all distros
https://wiki.pine64.org/wiki/Pinebook_Pr...iFi_issues
Looking at that guide here and following it, I have been unable to get my wifi card working at all, So I attempted to use a usb-to-Ethernet adapter with the same issue issues as the wifi.
The only thing that shows up from ip addr is the loopback interface. Thought it was the image so I used Balena etcher to re-setup the flash drive, no dice same issue. So I tried two other Distro's other than Manjaro (ubuntu and fedora) same problem. i also tried moving back to the 64gb module with no luck as well.
I am currently booting from a USB flash drive as i just swapped out to the 128gb eMMC module and have not installed an OS on it yet.
Is networking disabled via booting from the USB2.0 port?
  Armbian fix, current version now works Sb2024 0 3,130 08-08-2025, 08:49 AM
Last Post: Sb2024
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,704 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro network problem late 2023 acruhl 1 4,158 01-19-2024, 11:32 PM
  No Video Out on PBP on all major distros misha64 9 11,067 11-28-2023, 01:41 PM
Last Post: zaius
  More heavy network traffic leads to network break-down ericzolf 3 4,881 09-30-2023, 08:06 AM
Last Post: ericzolf
Brick Are there any usable/ stable distros for PBP? pineymousepad 16 19,263 05-24-2023, 10:06 AM
Last Post: Vinay
  Armbian is [edit: no longer] dropping support for Pinebook Pro TRS-80 4 8,492 12-23-2022, 12:01 AM
Last Post: TRS-80
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 3,749 09-30-2022, 10:09 AM
Last Post: crazyquark
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 8,240 08-25-2022, 02:15 PM
Last Post: Niko
  Network shared folder discovery (smb4k) solostian 10 21,448 12-06-2021, 07:27 AM
Last Post: solostian
