[Solved] SD Card strange boot behaviour
I have a pinebook pro running the Manjaro KDE default install everything is working fine. I'm very pleased with the device. I had ordered an additional eMMC of 128GB to replace the 64GB eMMC with. So I installed an other OS, Manjaro I3 SD card image, on a micro SD card I owned (samsung micro sd hc card of 32 GB read and write speeds not known..) and I am experiencing some weird boot issues.
Here are the scenario's:
- If I shutdown the pinebook pro insert the SD Card and power it on, I get the orange light, turning green, but the device won't boot from the SD-card.
- If I boot from the eMMC, insert the SD Card, mount the boot partition of the SD-card and restart the device, it boots without any issues from the SD-card.
Now if I want to replace the eMMC with the 128GB one I am not able to boot from the SD-card as it won't boot from a 'cold' start.
Might this be an issue with the SD-card being to slow? or is this some other problem? I've done the above two scenario's many times over and over again and it always succeeds when first booting up from eMMC, inserting the SD Card, mounting the boot partition of the SD-card and reboot.
(06-29-2020, 02:55 AM)benderni Wrote: I have a pinebook pro running the Manjaro KDE default install everything is working fine. I'm very pleased with the device. I had ordered an additional eMMC of 128GB to replace the 64GB eMMC with. So I installed an other OS, Manjaro I3 SD card image, on a micro SD card I owned (samsung micro sd hc card of 32 GB read and write speeds not known..) and I am experiencing some weird boot issues.
Try mounting your SD card boot partition, and editing the extlinux/extlinux.conf file for the SD card to add two dots before each slash as in this post: https://forum.manjaro.org/t/arm-stable-update-2020-04-02-kde-plasma-5-18-4-xorg-server-1-20-8-plasma-mobile-uboots-and-kernels/133266/2
I
 know it's not supposed to be required on a fresh image, but it solved it for me when I was in your exact scenario.
I
Thanks for the info, the extlinux/extlinux.conf file already contained the two dots before each slash. I tried /boot/ also instead of the two dots. But that didn't work either. So I'm still stuck on the cold boot issue from my SD card. I also updated the /boot/extlinux/extlinux.conf to contain the two dots. But that didn't help to boot from the SD card either.
Any other suggestions?
I got nothin'. That worked for me, so hopefully someone smarter than I will have a solution for you.
(06-29-2020, 05:31 PM)carlosqueso Wrote: I got nothin'.  That worked for me, so hopefully someone smarter than I will have a solution for you.
The solution you mentioned did work, upgraded to 128GB eMMC and was able to install via emmc installer image on the sdcard
A big thank you for pointing me in the right direction!
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,090 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,585 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 31,841 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 19,586 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,636 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,396 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,746 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,464 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,286 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,845 01-16-2024, 09:17 AM
Last Post: jbradley419
