Android sources
(05-16-2016, 08:37 AM)IlyaM Wrote: Do you know what does this line mean?
CHIPHD_LICHEE_DIR=builder@192.168.1.22:/home2/builder/release/a83-5.1/lichee
root@ilya-eME730G:/media/ilya/Data/A64/android# . build/envsetup.sh
including device/asus/flo/vendorsetup.sh
including device/generic/mini-emulator-arm64/vendorsetup.sh
including device/generic/mini-emulator-armv7-a-neon/vendorsetup.sh
including device/generic/mini-emulator-mips/vendorsetup.sh
including device/generic/mini-emulator-x86/vendorsetup.sh
including device/generic/mini-emulator-x86_64/vendorsetup.sh
including device/htc/flounder/vendorsetup.sh
including device/moto/shamu/vendorsetup.sh
including device/samsung/manta/vendorsetup.sh
including device/softwinner/astar-h7/vendorsetup.sh
including device/softwinner/astar-y3/vendorsetup.sh
including device/softwinner/astar-yh/vendorsetup.sh
including device/softwinner/common/vendorsetup.sh
including device/softwinner/jasmine-perf/vendorsetup.sh
including device/softwinner/kylin-p1/vendorsetup.sh
including device/softwinner/kylin-p2/vendorsetup.sh
including device/softwinner/octopus-f1/vendorsetup.sh
including device/softwinner/octopus-ibt/vendorsetup.sh
including device/softwinner/octopus-n1/vendorsetup.sh
including device/softwinner/octopus-perf/vendorsetup.sh
including device/softwinner/tulip-p1/vendorsetup.sh
including device/softwinner/tulip-perf/vendorsetup.sh
including device/softwinner/tulip-t1/vendorsetup.sh
including device/softwinner/zzzzz-chiphd/vendorsetup.sh
I got it when I use . build/envsetup.sh
It highlighted red
I have no idea but if you can run lunch command with tulip_t1-eng you should be fine.
Try to continue.
(05-16-2016, 09:00 AM)Hahaburger Wrote: I have no idea but if you can run lunch command with tulip_t1-eng you should be fine.
Try to continue.
Got a new problem when I was building the firmware
build/core/Makefile:34: Warning: override method for the purpose «out/target/product/tulip-t1/system/lib/hw/gralloc.default.so»
build/core/base_rules.mk:550: warning: the old way of the purpose «out/target/product/tulip-t1/system/lib/hw/gralloc.default.so» ignored
build/core/Makefile:34: Warning: override method for the purpose «out/target/product/tulip-t1/system/lib64/hw/gralloc.default.so»
build/core/base_rules.mk:550: warning: the old way of the purpose «out/target/product/tulip-t1/system/lib64/hw/gralloc.default.so» ignored
No private recovery resources for TARGET_DEVICE tulip-t1
make: *** No rule to make target «external/wpa_supplicant_8/wpa_supplicant/src/drivers/drivers.mk». Stop.
#### make failed to build some targets (12:25 (mm:ss)) ####
I haven't tried building from SDK but how you are trying to build? With make -j4?
You may try "make otapackage -j4" but Idk if they support it. I'm trying to download the new SDK Big Grin
yes with
make -j4
"make otapackage -j4" instead of "make -j4" gives me the same issue
Hi, have you got any success with SDK?
Sent from my iPhone using Tapatalk
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,969 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,754 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,860 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,000 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,071 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,626 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,347 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,963 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,556 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,398 02-10-2019, 07:44 PM
Last Post: mmmarcus
