Android sources
(05-16-2016, 08:37 AM)IlyaM Wrote: Do you know what does this line mean?
CHIPHD_LICHEE_DIR=builder@192.168.1.22:/home2/builder/release/a83-5.1/lichee
root@ilya-eME730G:/media/ilya/Data/A64/android# . build/envsetup.sh
including device/asus/flo/vendorsetup.sh
including device/generic/mini-emulator-arm64/vendorsetup.sh
including device/generic/mini-emulator-armv7-a-neon/vendorsetup.sh
including device/generic/mini-emulator-mips/vendorsetup.sh
including device/generic/mini-emulator-x86/vendorsetup.sh
including device/generic/mini-emulator-x86_64/vendorsetup.sh
including device/htc/flounder/vendorsetup.sh
including device/moto/shamu/vendorsetup.sh
including device/samsung/manta/vendorsetup.sh
including device/softwinner/astar-h7/vendorsetup.sh
including device/softwinner/astar-y3/vendorsetup.sh
including device/softwinner/astar-yh/vendorsetup.sh
including device/softwinner/common/vendorsetup.sh
including device/softwinner/jasmine-perf/vendorsetup.sh
including device/softwinner/kylin-p1/vendorsetup.sh
including device/softwinner/kylin-p2/vendorsetup.sh
including device/softwinner/octopus-f1/vendorsetup.sh
including device/softwinner/octopus-ibt/vendorsetup.sh
including device/softwinner/octopus-n1/vendorsetup.sh
including device/softwinner/octopus-perf/vendorsetup.sh
including device/softwinner/tulip-p1/vendorsetup.sh
including device/softwinner/tulip-perf/vendorsetup.sh
including device/softwinner/tulip-t1/vendorsetup.sh
including device/softwinner/zzzzz-chiphd/vendorsetup.sh
I got it when I use . build/envsetup.sh
It highlighted red
I have no idea but if you can run lunch command with tulip_t1-eng you should be fine.
Try to continue.
(05-16-2016, 09:00 AM)Hahaburger Wrote: I have no idea but if you can run lunch command with tulip_t1-eng you should be fine.
Try to continue.
Got a new problem when I was building the firmware
build/core/Makefile:34: Warning: override method for the purpose «out/target/product/tulip-t1/system/lib/hw/gralloc.default.so»
build/core/base_rules.mk:550: warning: the old way of the purpose «out/target/product/tulip-t1/system/lib/hw/gralloc.default.so» ignored
build/core/Makefile:34: Warning: override method for the purpose «out/target/product/tulip-t1/system/lib64/hw/gralloc.default.so»
build/core/base_rules.mk:550: warning: the old way of the purpose «out/target/product/tulip-t1/system/lib64/hw/gralloc.default.so» ignored
No private recovery resources for TARGET_DEVICE tulip-t1
make: *** No rule to make target «external/wpa_supplicant_8/wpa_supplicant/src/drivers/drivers.mk». Stop.
#### make failed to build some targets (12:25 (mm:ss)) ####
I haven't tried building from SDK but how you are trying to build? With make -j4?
You may try "make otapackage -j4" but Idk if they support it. I'm trying to download the new SDK Big Grin
yes with
make -j4
"make otapackage -j4" instead of "make -j4" gives me the same issue
Hi, have you got any success with SDK?
Sent from my iPhone using Tapatalk
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,259 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 598,983 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 49,318 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 31,407 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,432 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,882 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,354 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,589 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 402,423 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,326 02-26-2019, 11:58 AM
Last Post: Twistedx
