Android sources
Hey, where can I find the sources for Android (special for Pine64) to rebuild own firmware?
the wiki gives only finals img files, I'd like to remake it for myself.
I guess I need kernel sources
Android sources
And is there any instructions how to build your own firmware?
Look for the Binary Source Packages (BSP)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(05-14-2016, 08:36 AM)lenny.raposo-pine64.pro Wrote: Look for the Binary Source Packages (BSP)
Thanks for your reply!
I missed this section )
So, where can I find readme how to build it and set up the environment?
I found environment on google dev site.
I'm trying to make own build, what 's device I must choose for making it for A64 when I use lunch command
I have the next list:
You're building on Linux Lunch menu... pick a combo:     1. aosp_arm-eng     2. aosp_arm64-eng     3. aosp_mips-eng     4. aosp_mips64-eng     5. aosp_x86-eng     6. aosp_x86_64-eng     7. aosp_flo-userdebug     8. mini_emulator_arm64-userdebug     9. m_e_arm-userdebug     10. mini_emulator_mips-userdebug     11. mini_emulator_x86-userdebug     12. mini_emulator_x86_64-userdebug     13. aosp_flounder-userdebug     14. aosp_shamu-userdebug     15. aosp_manta-userdebug     16. astar_h7-eng     17. astar_h7-user     18. astar_y3-eng     19. astar_y3-user     20. astar_yh-eng     21. astar_yh-user     22. jasmine_perf-eng     23. jasmine_perf-user     24. kylin_p1-eng     25. kylin_p1-user     26. kylin_p2-eng     27. kylin_p2-user     28. octopus_f1-eng     29. octopus_f1-user     30. octopus_ibt-eng     31. octopus_ibt-user     32. octopus_n1-eng     33. octopus_n1-user     34. octopus_perf-eng     35. octopus_perf-user     36. tulip_p1-eng     37. tulip_p1-user     38. tulip_perf-eng     39. tulip_perf-user     40. tulip_t1-eng     41. tulip_t1-user Which would you like?
(05-15-2016, 03:05 PM)IlyaM Wrote: I found environment on google dev site.
tulip_t1-eng
(05-16-2016, 07:26 AM)Hahaburger Wrote: tulip_t1-eng
Thanks!
Now I have another problem, I set up oracle jdk7
But every time I get an issue
============================================ PLATFORM_VERSION_CODENAME=REL PLATFORM_VERSION=5.1.1 TARGET_PRODUCT=tulip_t1 TARGET_BUILD_VARIANT=eng TARGET_BUILD_TYPE=release TARGET_BUILD_APPS= TARGET_ARCH=arm64 TARGET_ARCH_VARIANT=armv8-a TARGET_CPU_VARIANT=generic TARGET_2ND_ARCH=arm TARGET_2ND_ARCH_VARIANT=armv7-a-neon TARGET_2ND_CPU_VARIANT=cortex-a15 HOST_ARCH=x86_64 HOST_OS=linux HOST_OS_EXTRA=Linux-4.4.0-22-generic-x86_64-with-Ubuntu-16.04-xenial HOST_BUILD_TYPE=release BUILD_ID=LVY48E OUT_DIR=out ============================================ Checking build tools versions... ************************************************************ You asked for an OpenJDK 7 build but your version is java version "1.7.0_80" Java(TM) SE Runtime Environment (build 1.7.0_80-b15) Java HotSpot(TM) 64-Bit Server VM (build 24.80-b11, mixed mode).
when I try to install openjdk
apt-get install openjdk-7-jdk
I got a message that you have to choose from the list
  oracle-java9-installer 9b116+9b116arm-1~webupd8~1
  oracle-java8-installer 8u92+8u91arm-2~really8u91~webupd8~0
  oracle-java7-installer 7u80+7u60arm-0~webupd8~1
How to solve this problem with idk?
(05-16-2016, 07:43 AM)IlyaM Wrote: when I try to install openjdk
Weird, maybe it was installed idk. Maybe you can try these:
sudo update-alternatives --config java sudo update-alternatives --config javac
if you see openjdk in output, select it.
(05-16-2016, 08:17 AM)Hahaburger Wrote: Weird, maybe it was installed idk. Maybe you can try these:
There is only one line:  /usr/lib/jvm/java-7-oracle/jre/bin/java
and there are no alternatives
I tried to reinstall that, removing everything with java, the same issue
maybe do I need remove $JAVA_HOME from environment?
(05-16-2016, 08:21 AM)IlyaM Wrote: There is only one line:  /usr/lib/jvm/java-7-oracle/jre/bin/java
I don't think you need to remove JAVA_HOME first you should install openjdk
If you are using Ubuntu have you tried searching openjdk on software center?
(05-16-2016, 08:30 AM)Hahaburger Wrote: I don't think you need to remove JAVA_HOME first you should install openjdk
Finally got it
sudo add-apt-repository ppa:openjdk-r/ppa   sudo apt-get update   sudo apt-get install openjdk-7-jre
Do you know what does this line mean?
CHIPHD_LICHEE_DIR=builder@192.168.1.22:/home2/builder/release/a83-5.1/lichee
root@ilya-eME730G:/media/ilya/Data/A64/android# . build/envsetup.sh including device/asus/flo/vendorsetup.sh including device/generic/mini-emulator-arm64/vendorsetup.sh including device/generic/mini-emulator-armv7-a-neon/vendorsetup.sh including device/generic/mini-emulator-mips/vendorsetup.sh including device/generic/mini-emulator-x86/vendorsetup.sh including device/generic/mini-emulator-x86_64/vendorsetup.sh including device/htc/flounder/vendorsetup.sh including device/moto/shamu/vendorsetup.sh including device/samsung/manta/vendorsetup.sh including device/softwinner/astar-h7/vendorsetup.sh including device/softwinner/astar-y3/vendorsetup.sh including device/softwinner/astar-yh/vendorsetup.sh including device/softwinner/common/vendorsetup.sh including device/softwinner/jasmine-perf/vendorsetup.sh including device/softwinner/kylin-p1/vendorsetup.sh including device/softwinner/kylin-p2/vendorsetup.sh including device/softwinner/octopus-f1/vendorsetup.sh including device/softwinner/octopus-ibt/vendorsetup.sh including device/softwinner/octopus-n1/vendorsetup.sh including device/softwinner/octopus-perf/vendorsetup.sh including device/softwinner/tulip-p1/vendorsetup.sh including device/softwinner/tulip-perf/vendorsetup.sh including device/softwinner/tulip-t1/vendorsetup.sh including device/softwinner/zzzzz-chiphd/vendorsetup.sh CHIPHD_LICHEE_DIR=builder@192.168.1.22:/home2/builder/release/a83-5.1/lichee
I got it when I use . build/envsetup.sh
It highlighted red
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,792 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 613,808 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,681 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,319 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,817 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,419 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,703 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,837 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 412,331 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,620 02-26-2019, 11:58 AM
Last Post: Twistedx
