Sound stuttering on Manjaro gnome after latest kernel upgrade?
Usually the sound on my PBP has been fairly good, but the most recent set of Manjaro stable channel updates I've been getting stuttering/cutouts in videos played via chrome.
Checking the logs they're full of acpi messages about the sound. I stopped apcid service with
systemctl stop acpid
and manually restarted it from the command line with:
acpid
and the problems have gone away. Anyone know what the cause is or suggest any possible solution?
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,146 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,587 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,236 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,356 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,104 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,649 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,001 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,248 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,486 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
