Pinephone not receiving SMS. SMS not showing on modem either.
Haven't received sms for about a week. I am able to send SMS. I am on Mobian and phosh. My carrier is Verizon
Here is what I have tried:
  • running the mmcli to check for and delete sms. However MMCLI claims there is no messages.
  • Janky-mms which I think probably just uses mmcli and had the same result.
  • minicom -D /dev/ttyUSB2 with a couple of different commands (I can't find where I got these commands but they were supposed to clear the cache and reset the modem I think.)
  • Changing APN
  • Ran the following to check for messages on modem. Like above it showed nothing
    socat - /dev/ttyUSB10,crnl AT+CMGL
I don't know if Journalctl shows anything interseting but here it is should anyone want to see it
https://pastebin.com/H8KxJUyK
Thanks in advance for any help.
Sorry I can't help about your provider.
Since the last update of Saturday, I could receive and send SMS.
In the Parameters application, what can you see in the 'Modem Details' ?
(03-22-2021, 03:34 PM)Gribouille Wrote: Sorry I can't help about your provider.
Carrier: Verixon Network Type: lte Signal Strength: 49% Network Status: Registered Manufacturer: QualComm Incorporated Model: Quectel Mobile Broadband Firmware Version: EG 25GGBR07A08M2G IMEI 867698044818253
Carrier: Verixon Network Type: lte Signal Strength: 49% Network Status: Registered Manufacturer: QualComm Incorporated Model: Quectel Mobile Broadband Firmware Version: EG 25GGBR07A08M2G IMEI: xxxxxxxxxxxxxxxx
Same network type and firmware for me.
I changed a setting inside the vzwinternet apn to allow data when roaming. I think I was tinkering and forgot I changed it. For some reason having that set to on blocks all incoming sms. Unfortunately it appears all the previous sms that I should have received are gone and I won't be receiving them.
  Mobian image for the PinePhone Korfou 2 2,114 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,827 12-24-2025, 12:11 AM
Exclamation Cannot flash the modem firmware anonymous 9 13,933 12-17-2025, 01:42 AM
  cryptocurrency on mobian/pinephone biketool 33 75,342 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,351 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,569 06-07-2025, 03:19 PM
  Logging modem dialout attempts biketool 2 3,494 04-11-2025, 02:47 AM
Last Post: vusra
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,386 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,658 01-02-2025, 12:47 PM
Last Post: zetabeta
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,747 12-01-2024, 07:54 PM
Last Post: dchang0
