Pinephone seems tobe using 4G data instead of Wifi data
I am outside of the "Glorious EU Data Roaming Area" for the first time since getting my PinePhone
On arriving at my destination I turned off Aeroplane Mode on my PinePhone and connected to the local Wifi network. I did not turn off the cellular connection.
This morning after watching a few videos last night I discovered that my PinePhone appears to have chomped its way through 400 MB of cellular data that is not included in my monthly subscription instead of using data via the Wifi connection.
Has anyone experienced anything similar?
PS I have now disabled Mobile Network in Settings
Same functionality here. I now turn off the mobile data before downloading updates.
Device: PinePhonePro (Daily driver)
OS: DanctNIX Arch with Phosh
(06-25-2024, 10:38 AM)mikehenson Wrote: Same functionality here. I now turn off the mobile data before downloading updates.
Interesting.
A couple of days later the company I have my plan with sent out an SMS saying that they had had some sort of problem with partners in foreign countries. The credited me with all of the excess data used when I was on holiday.
So I am not sure now if the problems my provider had were the primary cause of the excessive use of cellular data or if it is something to do with PinePhones in general that the cellular connection gets prioritised in certain situations.
I will keep my eye on it next time I am out of the EU roaming area.
i have only used pinephone and pro in home network. but in my experience mobile data toggle works as intended. mobile data toggle is different than mobile network toggle. i use data toggle even in home network areas.
some specific devices, not pinephone, mobile data toggle does not function in full. in reality, mobile data is left on in a background and operating system's firewall prevent data in and out. this may lead to unexpected behavior, like charges. luckily these devices are rare.
Most Linux installs default to IPv6 if available over IPv4 connections. The mobile data connections could be dual stack while the WIFI is just IPv4. The result is IPv6 connections and data are made over mobile instead of IPv4 on Wifi.
No all internet services support IPv6 which leads to mixed results. Debian Repos, Google, Facebook and I guess some streaming services support IPv6. This is a why Mobian and Debian updates will seem to use mobile data while other usages do not.
(12-28-2024, 11:12 AM)puffchumpy Wrote: Most Linux installs default to IPv6 if available over IPv4 connections. The mobile data connections could be dual stack while the WIFI is just IPv4. The result is IPv6 connections and data are made over mobile instead of IPv4 on Wifi.
that's the case if you do not toggle mobile data switch.
but you could toggle mobile data switch and i recommend to. i do it even in home network.
some devices, like some android, some kaios devices, leave mobile data on even if toggle is off. these devices just firewall mobile data in a way that mobile data is active. hell of nightmare for some cases like roaming. i even heard that iphones have been partially guilty for this.
maybe i test this in pinephone, but i don't think i come to a different conclusion.
The reasons for using a firewall and keeping model data on might be MMS content download. Unless some type of calling over wifi is active, MMS content generally needs to be downloaded via the data connection from the Mobile service server. If mobile data is turned off on a pinephone then MMS content will not be retrieved. Turning on mobile data to down the content and then turning off is probably best while roaming. I wonder if this could be fixed by having the modem firmware download MMS content and provide it to the chat application, SpaceBar or Purple.
The modem stack is using data for 4G voice calls since VoLTE seems to be more like VOIP. 3G voice calls seem to work differently, even if it's really just data in the end. Phones that have an integrated CPU/Modem chip stack might need the firewall rules to enable the VoLTE data calls while limiting the other data usage. The PinePhone modem seems to provide some separation between modem and main OS, so 4G VoLTE calls work without mobile data active.
I would turn off mobile data if I was in a costly mobile data location. I've tried some firewall rules that would be applied based on DBUS networking events, but I didn't get it work as desired yet.
Updated my mobian trixie installation to block IPv6 when wifi wlan0 is up with some exceptions. In order to receive, send or download MMS messages mobile data is needed. My carrier is an MVNO on the USA T-Mobile network. I found that enabling IPv6 to the T-Mobile defined ISP IPv6 internet space solved the problem. This enables DNS and interactions with the T-Mobile services that support MMS.
My setup adds firewall rules allowing IPv6 OUTPUT to T-Mobil(2607:7700::/32) and blocks all other IPv6 on wwu1i4. If wifi is not up then the rule is removed to enable data via IPv6 over mobile data.
Bash script added to:
Quote:/etc/NetworkManager/dispatcher.d/99-manage-ipv6-rules.sh
#!/bin/bash INTERFACE="$1" STATUS="$2" if [ "$INTERFACE" == "wlan0" ]; then     if [ "$STATUS" == "up" ]; then         # wlan0 is up, apply the ip6tables rules         if ! ip6tables -C OUTPUT -o wwu1i4 -j DROP 2>/dev/null; then             # Rule not present, add the rule             ip6tables -A OUTPUT -p udp --dport 53 -j ACCEPT             ip6tables -A OUTPUT -p tcp --dport 53 -j ACCEPT             ip6tables -A OUTPUT -d 2607:7700::/32 -j ACCEPT             ip6tables -A OUTPUT -o wwu1i4 -j DROP         fi     else         if [ "$STATUS" == "down" ]; then             # wlan0 is down, remove the ip6tables rules             if ip6tables -C OUTPUT -o wwu1i4 -j DROP 2>/dev/null; then                 # Rule present, remove the rule                 ip6tables -D OUTPUT -o wwu1i4 -j DROP                 ip6tables -D OUTPUT -d 2607:7700::/32 -j ACCEPT                 ip6tables -D OUTPUT -p tcp --dport 53 -j ACCEPT                 ip6tables -D OUTPUT -p udp --dport 53 -j ACCEPT             fi         fi     fi fi
Hoping this will prevent mobile IPv6 usage when the phone is connected via wifi that is IPv4 only. Application IPv6 connections should fail falling back to IPv4 while MMS messages should continue to work.
If T-Mobile starts hosting debian repo on there IPv6 space then then I'll have a problem. Or will have to be more specific with the allowed IPv6 ranges.
  Mobian image for the PinePhone Korfou 2 2,070 04-27-2026, 09:57 AM
Last Post: Korfou
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 7,558 03-10-2026, 04:43 PM
Last Post: baptx
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,526 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,171 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 356,843 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,520 06-07-2025, 03:19 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,643 01-02-2025, 12:47 PM
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 10,149 01-08-2024, 02:50 PM
Last Post: ERPlegend
  4G data on default startup / boot dcinoz 1 3,222 04-29-2023, 11:24 PM
Last Post: dcinoz
  Wifi doesn't work after update nickolas 2 4,953 04-14-2023, 10:07 AM
Last Post: nickolas
