Logging modem dialout attempts
My Pinephone Pro running Trixie is able to do everything normally re:modem except successfully dial out, that includes taking incoming phone calls.
I am not sure where the logging is kept to look for errors etc when accessing the modem in order to troubleshoot the issue, possibly also need to look at logs inside the modem module OS.
Has anyone else had this issue in the current trixie since middle of last week?
The SIM dials out successfully in a 4g dumb Nokia.
I am looking around and I would like to find the documentation on how the phosh calls app triggers a call vs perhaps dialing on the CLI, lockfiles etc so I can see where the call is failing.
Unfortunately some of the mmcli example websites have bitrotted away so we dont have the required documents to do a CLI test...
(edit)
ma mmcli helped a little
mobian@mobian:~$ sudo mmcli -m 0 --voice-create-call=number=1231231234(fake number for this post)
Successfully created new call: /org/freedesktop/ModemManager1/Call/1
but it throws no CLI error just fails with a doo doo doo tone and is done.
references:
https://forum.pine64.org/showthread.php?tid=12225
https://forum.pine64.org/showthread.php?tid=11815
https://www.alsatux.com/Pinephone
there are some powerful mmcli tools to do things like clear stuck SMS/MMS and other things but finding the documentation is a matter of scraping hundreds of blog and forum posts some of which are referred to as master documentation but are not online anymore.
(edit)
I forced 2g and now I can out dial over the CLI and calls app and it works in/out...(I had thought I had tried this before)
3g - voice in/out works, data/SMS works
4g - voice(call out fails in app and cli, no cli error) but can receive voice calls, data/SMS works (same SIM works on 4g with newer Nokia dumb phone...IDK)
Ideas?
dmesg -Tw --level=err,warn
to watch kernel ring warnings and errors as they happen
journalctl -xef
to watch sytemd journal entries as they happen
Run these each in their own terminal. On third terminal run nmcli and see what error shows.
Exclamation Cannot flash the modem firmware anonymous 9 13,618 12-17-2025, 01:42 AM
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,579 12-01-2024, 07:54 PM
Last Post: dchang0
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 11,050 06-06-2023, 06:36 AM
Last Post: freelectro
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,822 02-27-2023, 04:18 PM
Last Post: calinb
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 14,811 09-23-2022, 05:15 AM
  Phosh modem on/off effectiveness? Zebulon Walton 0 2,401 01-24-2022, 09:21 AM
  Modem suddenly not enabled when booting from eMMC Zebulon Walton 3 6,185 10-23-2021, 01:55 PM
  Cell modem mmd604 12 18,975 10-03-2021, 08:43 PM
Last Post: calinb
  Eliminate swiping/logging in when waking up from suspend? Zebulon Walton 5 8,650 08-13-2021, 06:15 PM
  Using the "Modem Manager GUI" bcnaz 0 2,758 08-02-2021, 06:49 PM
Last Post: bcnaz
