Pinebook pro crashing when put to sleep?? [Manjaro]
Hijacking as well to say that downgrading from 5.9 to 5.8 fixed a bunch of other issues for me besides sleep, around memory/swap. In case anyone is having similar issues with freezes around swapping and memory not being released properly after terminating a process
I confirm severe kernel memory management problems on 5.9 and 5.10-rc's.
As of now (5.9.3 and 5.10-rc2) are unusable.
EDIT:
I just compiled 5.9.4 - same situation - unusable.
EDIT 2:
They released 5.9.5 shortly after 5.9.4. Compiled it and it has no leak. It was panfrost leaking.
There is also a bug in Mutter7, causing gdm to crash when you return from sleep or even from lockscreen
Sleep is often problematic, I haven't really tried on the PBP.  I try to not close the lid, I grab the left side and stand it up on the floor to put it down.  With the screen and keyboard being at right angles it stands up quite nicely on its side.
I haven't bothered to play with it because getting my SSD to boot is more important, but I wonder if a dedicated sleep partition would  work better than a file.  4 GB isn't that much space to give up, even on an SD.  Using a swap file doesn't seem like it would work very well if something happens to be swapped out when you start to go into sleep.  Swap and sleep will run into each other and I don't think either checks for the other.  I set up a 10 GB swap partition on my SSD that seems to work fine.
  Boot Order in Pinebook Pro food 12 13,999 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,741 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,011 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,353 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,948 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,643 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,919 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,859 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,483 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 3,597 03-08-2024, 08:41 AM
