Pinebook pro crashing when put to sleep?? [Manjaro]
What is happening: trying to put pinebook pro to sleep results in complete death of the laptop. Power light goes off, screen goes off and it absolutely refuses to come back alive. I have to hold the power button for 7 seconds, and turn it back on to get to to work. Otherwise it absolutely refuses to show any signs of life.
What I tried: removing swap file completely
Started happening since I ran the updates through software updater. Before that it was working fine for a good week since I first got the laptop.
Given I am a beginner at linux, I am not even sure how to begin to debug something like that. Any help would be appreciated.
Me too, the new kernel, for s3 is no good
install downgrade, as root/sudo ,,,, downgrade linux
(10-28-2020, 01:06 PM)wdt Wrote: Me too, the new kernel, for s3 is no good
uh... how do I do that, exactly?
Sorry I'm a noob at linux, I feel like I'm 5 years old here... of you have instructions on how to do that exactly please send them my way Smile
also check out my sister thread on reddit about this issue: https://old.reddit.com/r/pine64/comments...p_manjaro/
the guy just said that trying to downgrade resulted in a laptop that can't even boot to begin with.....
downgrade is a package, install like any other package,, then
sudo downgrade linux,,, it gives a menu, choose version, answer if you want it "pinned"
It may be in arch, not sure, so that repo should be enabled if downgrade not found
If you are using kde,, systemsettings5 for ->power management ->button handling checked,,
ignore lid close, pwr button ask
(10-29-2020, 12:05 PM)wdt Wrote: downgrade is a package, install like any other package,, then
I'm sorry, these instructions weren't entirely clear, because I am still very very new to linux, especially manjaro...
my deductions point me to reason that it is precisely last nights update that caused this crashing to occur, so I would like to try rolling that precise update back if that's what your last message was referring to
Do you not know how to install packages? On the bottom bar, to the right is a shield
When there are upgrades it is red, click on it, open package manager
control f (to find), type downgrade, click button to put a check on install, bottom right apply, password
OR,, you could install from terminal,,, sudo pacman -Sy downgrade
Then open a terminal, any will do,,, alt space, when box opens at top type konsole, enter
then,
sudo downgrade linux,,, a menu will appear, pick a number
Yes, the new kernel causes s3 to fail to wake
(10-29-2020, 07:43 PM)wdt Wrote: Do you not know how to install packages?  On the bottom bar, to the right is a shield
then,
It only shows "Firmware (gnome-firmware) 3.36-0-2"
Is that the one I should choose?
also apparently "downgrade" is not identified by my console, says "command not found". gonna install the downgrade from package manager and try again now...
[update] nope, still says "downgrade: target not found" and "downgrade: command not found"
sorry if my question is borderline mentally handicapped because it's probably piece of cake for guys like you, but I'm still very very new to linux, as eager as I am to learn all about it.
thanks in advance Smile
OK, as I thought I remembered, it is from the arch distro, Manjaro is an offshoot of arch,,
usually they are binary compatible, you have to enable the arch repository
Bear with me I did this 8 months ago, forget,,...
Open the gui, package manager, top bar, right, hamburg button ->preferences -> AUR ->enable AUR
The name will be downgrade, version #,,,, nothing else, not even capitalized
If you like scripts, it's just a clever bash script, plain text, you can look at it
(10-29-2020, 09:19 PM)wdt Wrote: OK, as I thought I remembered, it is from the arch distro, Manjaro is an offshoot of arch,,
UPDATE: seems to have solved the issue now
here's what I did, step by step:
1) [alt+space], "add/remove software", software manager shows.
2) right below the "X" button at the top right, clicked the three lines -> "Preferences"
3) hit AUR tab, and enable AUR support
4) go back to software manager, search "downgrade". Pick the one with description "bash script for downgrading one or more packages..."
5) download and install it. When done, open a terminal (I used konsole) and type "sudo downgrade linux". Pick the version one before your current one (for me it was 5.8....)
6) proceed with the prompts when asked "yes/no"
7) sudo reboot now
8) sleep to idle seems to work again Smile
obviously I wouldn't have done it without you, wdt. Huge thanks for that Smile
Good, my impression, BTW is that 5.8 is not quite as good as previous versions,
let me know in couple days what you think (ie more battery drain/day)
  Boot Order in Pinebook Pro food 12 19,114 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,505 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,238 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,664 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,366 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,474 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,651 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,760 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,472 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 4,181 03-08-2024, 08:41 AM
